Bluescreen Crash
Best Answer johnnyrenshus , 16 August 2013 - 05:51 AM
Hi!
I think I've found out what the errors was all about! I have always been Connected through a USB 3.0, but when I Connected it via the 2.0 it hasn't crashed! (yet) :D
Doesn't really know why since the 3.0's DOES work With anything else...
Go to the full post
14 replies to this topic
#1 johnnyrenshus
johnnyrenshus
  • 4 posts
  • Registered Products:2
Posted 14 August 2013 - 03:10 AM
Hi there!
It might been answered on this forum before, but I've searched my lollipop of and ragequited maaaany times by this error crashes.
I've conected my HD PRO via USB, in Windows 8 I've selected that all the sound (from Spotify or FL studios for instance) will be played throgh the HD PRO. It Works fine and I can play through the HD PRO With no problem With Spotify or whatever. But when I want to records something, and I'm using "ASIO POD Hd Pro" cause it got the lowest latency. When I've played for a couple of Seconds to minutes the PC crashes. I've got different error Messages like: "BAD_POOL_HEADER" or "L6HDPRO64" or "SYSTEM_THREAD_EXEPTION_NOT_HANDLED".
I have updated the Monkey program and the HD PRO! I did it 5 minutes ago and it still crashes. I sent even Line 6 a e-mail, but did never get any answer... :( I've also flashed it a month ago, With no Luck. (had the same problems then, and I read it might work, but didnt).
I've got 12gb RAM and a 3,6 GHz Quad-Core processor, so I really dont hope that my computer is too old and bad to use it. The only thing that I think might be the program is that my standard soundcard is broken, but I do not use it! After all, Ive conected all the sound via USB and into the HD PRO...
Please help, I'm almost going crazy and havent found any solutions yet that really work...
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7369 posts
  • Registered Products:6
Posted 14 August 2013 - 03:35 AM
Is you PC an AMD machine?
If so try removing the USB filter, it is usually bundled with the Catalyst software.
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 14 August 2013 - 04:13 AM
i'd suggest trying slimdrivers (google it) its free...
there's more going on than just the audio driver...
slimdrivers will help you get chipset, usb, and other motherboard related drivers.
won't hurt to check... but there's not alot of upgraded drivers etc related to windows 8... since its pretty new and no one really wants it...
I use it and it's a mess...
#4 johnnyrenshus
johnnyrenshus
  • 4 posts
Posted 14 August 2013 - 07:56 AM
Thanks for answer. Yes, its an AMD computer. And I will check it out, and check if all my drivers are up to date and stuff. But the weird thing isthat for some months ago I removed W8 and installed W7 and Linux Ubuntu but I got the same error messages on both systems! :S
#5 Guitarmaniac64
Guitarmaniac64
    Iknowathingortwo
  • PipPip
  • 258 posts
  • Registered Products:3
Posted 14 August 2013 - 12:35 PM
Hmm i think it is a win 8 problem have they done something new in the audio section since Win7?
I wouldn´t care so much for the date of drivers unless they are not working at all and not functional i have used Vista drivers in Win7 and it have worked fine..
In Win 7 you can have more than one audio driver active at the same time.
If you have more than one driver active you might change driver in your spotifyplayer to the built in audiodriver it is usually in the preferences or option menu so you can have the POD drivers only for recording..
And what program are you recording with??
Cubase & Studio One have an option called release audiodriver in background so you can use several auidio applications simultaneouse other DAW may called different but i am pretty sure most DAW have that option nowadays..
Another way is to make the built audio driver inactive everytime you want to use the POD HD driver..
But that require that you need to remember that and go to the controlpanel and change it every time..
But if that is the only oprtion you may have no choice..
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 14 August 2013 - 12:38 PM
I'd advise you to disregard this statement. ASIO4ALL is not a "great driver" it is a reverse engineered 3rd party open source attempt at faking compliance with the ASIO specifications.
it's use is for products that do not have real genuine ASIO compliant drivers available... which is not the case here.
Another great driver is ASIO4ALL with that you can have both drivers active..
#7 Guitarmaniac64
Guitarmaniac64
    Iknowathingortwo
  • PipPip
  • 258 posts
Posted 14 August 2013 - 09:07 PM
Yeah that is correct it is a reverse engineered poject but that doesnt mean it is NOT GREAT
Hey i have used that driver many times and with low latency and atleast it is NOT CRASHING my system like Line 6 drivers and other soundcard driver has..
I know there is better ones out there but they cost money this one is FREE and a very useful option if your soundcards driver i.e Line6 does not work as it suppose to..
#8 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 15 August 2013 - 03:36 AM
where is this statement that you quoted from guitarmaniac64? i can't find it in his post. has it been removed?
Guitarmaniac64, on 14 Aug 2013 - 16:39, said:snapback.png
I'M SO HAPPY!
#9 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 15 August 2013 - 04:21 AM
you THINK you've gotten low latency... a driver that does not adhere to the ASIO spec... is somehow delivering accurate latency measurements to a specification that it doesn't adhere to... yeah right.
ASIO4ALL is a good workaround for audio cards whose manufacturers do not provide ASIO compliant drivers...
ASIO4ALL also does not give you all the benefits of your hardware...
i guess its good enough for you... not sure how that = great....
but just because the driver itself says its better (because it reports some made up latency number)
does not make it so.
it also does NOT work how line6 drivers are supposed to... there are specific hardware enhancements, as well as a strict adherence to the ASIO specification that ASIO4ALL does not provide.
also the ability to use more than 1 audio driver/card is COMPLETELY outside of the ASIO specification...  (i.e. impossible to be compliant)
the ASIO specification calls for all inputs/outputs to be controlled by a singular hardware clock, which is how the accurate latency is reported.
#10 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 15 August 2013 - 04:25 AM
He may have removed it himself, but his post was not moderated.
#11 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 15 August 2013 - 04:54 AM
i know
I'M SO HAPPY!
#12 johnnyrenshus
johnnyrenshus
  • 4 posts
Posted 15 August 2013 - 05:15 AM
I did try the USB filter thingy, got another error Message now... (didn't get it before the PC restarted)
Sorry, I do not know if they have done something New in W8 in the audio settings :( But I have now disabled everything except the HD PRO, and still error Messages.
I'm using both FL Studios and Mixcraft 6.
Thanks People for being so helpful and Learning me about ASIO4ALL (HAHA! :D )
#13 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7369 posts
Posted 15 August 2013 - 06:16 AM
Have you tried different USB ports and cables?
If you haven't already, submit a support ticket.
http://line6.com/support/tickets/
#14 johnnyrenshus
johnnyrenshus
  • 4 posts
Posted 16 August 2013 - 05:51 AM   Best Answer
Hi!
#15 Guitarmaniac64
Guitarmaniac64
    Iknowathingortwo
  • PipPip
  • 258 posts
Posted 17 August 2013 - 11:29 PM
I can see now that it is a language problem here GREAT for me means GOOD
American/English is NOT my native language and i´ve learn it from watching many TV-shows Movies & reading the lyrics and thank you notes on old Vinyl LP covers in school i was not so interrested to learn ANYTHING hence my spelling/grammar problems..
Anyway i belive what is GREAT for you probably means SUPERB or BRILLIANT for me..
But your right it is NOT "great" it is GOOD.
