Usb Bypassing Internal D/a Conversion?
7 replies to this topic
#1 BlueViolince
BlueViolince
    Iknowathingortwo
  • PipPip
  • 268 posts
  • Registered Products:1
Posted 14 August 2013 - 09:33 AM
Just thinking for recording purposes, to eliminate any unnecessary conversion stages. In an unrelated note, does the D/A and A/D in the fx loop put any kind of a hit on dsp? Or are all of the conversions running on dedicated processors?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8237 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 14 August 2013 - 09:48 AM
To answer your question in the title, yes the USB audio out bypasses the D/A conversion at the analog outs. Using the FX loop would add another layer of conversion. I suppose putting the loop in a tone uses some DSP, but it's probably very minimal. The converters would be separate chips.
#3 BlueViolince
BlueViolince
    Iknowathingortwo
  • PipPip
  • 268 posts
Posted 14 August 2013 - 10:05 AM
That's what I thought. For the fx loop, it doesn't make a difference when recording, but it doesn't make sense that it uses an active effect block if it's not pulling on the dsp, am I right? I would love it if the next firmware did something about that.
#4 BlueViolince
BlueViolince
    Iknowathingortwo
  • PipPip
  • 268 posts
Posted 14 August 2013 - 10:11 AM
... Not that I've checked Monkey once in the past three months expecting to see a new update...
#5 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8237 posts
Posted 14 August 2013 - 10:12 AM
Well, what would you propose they do with it? I don't see a really clear alternative that still makes it so you can put the effects loop anywhere in the chain and have it controllable with a footswitch.
#6 BlueViolince
BlueViolince
    Iknowathingortwo
  • PipPip
  • 268 posts
Posted 14 August 2013 - 10:22 AM
I'm just saying, 8 blocks are there, no matter what's in them. The fx loop takes up a space, whether it uses dsp or not. I have patches that aren't maxed out on dsp, but have no room for the loop because every block is full.
#7 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5240 posts
  • Registered Products:6
Posted 14 August 2013 - 11:46 AM
Then something has to give right? Use it for what it does now, not what you think it should do...By all means discuss it and send Line 6 a feature request, but I would suggest that you try not to hold your breath on this one. One way you could work around the need for 8 (or more) FX in the chain is to 4CM an HDPro, M-13....Heck and M-5 would give you the 8th effect and you could have spring reverb all the time...Line 6 is not always going to solve all your issues and yes, they want you to have GAS...
#8 BlueViolince
BlueViolince
    Iknowathingortwo
  • PipPip
  • 268 posts
Posted 14 August 2013 - 12:27 PM
Oh, I realize that L6 is trying to sell more gear, and I haven't even looked for updates on Monkey in months. It was more of an afterthought/sidebar to my title question. And I thought I was done with stompboxes...
