Pod Hd500x Mapping Program Changes To Strymon Timeline
hd500x midi midi program change midi controller
4 replies to this topic
#1 catfly
catfly
  • 1 posts
Posted 14 August 2013 - 02:29 PM
I am trying to map program changes sent to the Timeline. Currently the Timeline sees 1-to-1 from the Pod, meaning as I step through my Pod presets the Timeline will follow sequentially. I don't want to have to match the position of the Timeline's presets to that of any given Pod Playlist that I'll be using for live performance - I'd like to map each Pod preset to a Timeline preset by sending a simple program change. I have followed the POD Advanced User Guide to the letter, but it persists in sending program changes to the Timeline sequentially. Anyone else have this problem? Thanks in advance for any help!
#2 stevieadams
stevieadams
  • 2 posts
  • LocationLos Angeles
Posted 15 August 2013 - 06:12 PM
Ok, let's take the Strymon Timeline out of the equation. Has anyone here succesfully mapped MIDI program changes to ANY outboard gear from the HD500, or 500x? Thanks!
#3 glideman
glideman
    Gear Head
  • PipPipPip
  • 640 posts
  • Registered Products:4
Posted 14 October 2013 - 10:07 AM
I've used it to control and Eleven Rack, but did not route signal through the HD500.
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9057 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 14 October 2013 - 10:33 AM
The 500X's MIDI map is what it is... It can't be changed. What you could do, and I know it's not quite as elegant, is to make it so the TimeLine and HD500X are set to different MIDI channels, and then in side your presets in the HD500X program a footswitch to send whatever PC message (on whatever channel you have the TimeLine set to) you need. As long as two devices are set to different channels, you won't have to worry about the HD500X sending messages you don't want the TimeLine to respond to.
#5 alexisltd
alexisltd
  • 53 posts
Posted 15 October 2013 - 11:28 PM
in other words....the pod HDs (and every line6 product for this matter) are complete trash in the MIDI  department !!! (the only way to use the midi function its like a very basic,outdated and simple midi controller)
I had to sell my beloved HD500 because he could not do send midi PC messages mapping to a nova drive pedal !!!! (nova drive only 18 presets so the midi mapping was mandatory in order to integrate the nova drive)
Also tagged with one or more of these keywords: hd500x, midi, midi program change, midi controller
