No Audio While Trying To Record With Mic In Cubase And Podfarm Or Just Messing Around In Pod Farm 2.5
pod farm mic failure no audio ux1
32 replies to this topic
#1 deepseahunter
deepseahunter
  • 22 posts
  • Registered Products:1
Posted 14 August 2013 - 05:15 PM
I am using a UX1 which works perfectly fine for my guitar and recording in cubase for my guitar but now I am trying to record JUST vocals, my guitar isn't even plugged in and I can't figure out how to set it up I use Asio4all in cubase and can't even find VTS autobay in that to operate what I have found in so many things...but that's not the main problem (even though it is a problem.) I can't even get any audio in Pod Farm 2.5 I did what was suggested in one forum but it did nothing (simply opening the mixer...which doesn't sound like it would fix any problem)
No I do not have a phantom power mic,
so there should be literally no problem, but I understand it's obviously not plug and play like using a guitar.
Help with cubase would be a godsend,
but help with just being able to work with my mic in pod farm would be awesome and much appreciated.
thank you,
DSH
#2 deepseahunter
deepseahunter
  • 22 posts
Posted 14 August 2013 - 05:43 PM
I've also tried all other drivers and none of them work, and the ux1 one doesn't even allow me to mount the ux1 as a device to be used...
#3 deepseahunter
deepseahunter
  • 22 posts
Posted 14 August 2013 - 06:15 PM
I found out I needed to set it to mic 1 but now I am getting a mic reading but no audio.
so how do I solve this problem?
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 14 August 2013 - 06:52 PM
you're primary issue is that you're trying to use ASIO4ALL.... you need to use the line6 drivers... then the line6 control panel will let you change inputs.
#5 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 07:27 AM
I perfert Asio4all, I can never get the line6 divers to work when I uninstall asio4all to do that, I got the mic to work with podfarm but I still can't get it to work with cubase because it doesn't give me the option of changing the input to mic from instrument at all, the mixer doesn't even have that portion 2wovy28.png and in case that doesn't work http://tinypic.com/r/2wovy28/5 even when I remove the other podfarms from inserts it doesn't help me fix the problem. because that section just doesn't exist
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 15 August 2013 - 07:33 AM
Do what you can, then... but Line6 does not support ASIO4ALL, and if you insist on using it, you won't be getting any support from them.
#7 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 07:41 AM
as well, when I just now deleted asio4all, which is all that seems to work, I can't get my mic to work with the mic settings at all on podfarm in cubase, but it makes a hell of a noise with the guitar settings but no vocal audio either way. which I can't even get my guitar to play through because none of the choices in vts connections work... so your advice doesn't really help.
#8 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 07:49 AM
now I got it to slightly work, but now there is this weird feedback and delay that comes through and it doesn't work properly, and it reverberates I'm unsure what that problem would be.
#9 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 07:52 AM
to correct my last statement only my computer's mic works, not the external. o9o0nm.png
#10 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 07:59 AM
and my interface doesn't work properly with this program meaning no sound for my guitar
#11 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 08:17 AM
got the guitar to work from updating with monkey, but mic just gives me fuzz with the external mic choice, can't figure this out
#12 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 03:46 PM
I hope I'm not getting ignored now because I mentioned asio4all....
#13 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 15 August 2013 - 03:48 PM
No... this is a user forum and no other user has an answer for you...
if you want line6 to help you: http://line6.com/support/tickets/
#14 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 03:57 PM
Oh I thought you were a support guy, I figured there were some in here...Hope they can help me. do you have any idea what would cause the mic to give feedback in cubase and podfarm (even though it works in standalone) but not give any mic sound at all?
#15 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 15 August 2013 - 04:01 PM
can't say that I do... but i would try other mics and cables... look for any trim settings or any sort of "+20db" type booster settings.
#16 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
  • Registered Products:6
Posted 15 August 2013 - 04:09 PM
You would not select mic in Cubase, you would select it in POD Farm.
Also check you Sends in POD Farm's mixer view.
And when you arm tracks to record make sure you select the correct send(s).
#17 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:11 PM
what are these sends? there is no place to select the mic in podfarm when I am in cubase though only in standalone...I do get mic feeback from boosted audio but no sound.
#18 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
Can you please elaborate on this?
btw, Zap IS a support guy, I've seen him support a wall ALL DAY LONG!!  :lol:
not really, but I'm cracking myself up nonetheless!!
#19 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:15 PM
The mic works when In standalone which is pretty simple, but when in cubase I get boosted feedback from having the mic plugged in and external mic selected in stereo input, but I get no mic audio, the mic works fine, it's something that is going on with cubase or with podfarm in cubase. Or something isn't set up properly at all. I get levels but not when I talk into it just from the signal being boosted.
#20 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
The sends are in POD Farm's mixer view.
I haven't used Cubase in years, so it might be called something different.
For example, in Reaper I select Line6 ASIO as my device and enable all 4 sends in the prefences.
Then when I arm a track to record I have available mono input 1,2,3, or 4 or stereo 1-2, 2-3, 3-4.
Clear as mud, right?
So it may be Cubase names them something else.
#21 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
Posted 15 August 2013 - 04:16 PM
Do you have monitoring turn on in Cubase? Typically you should not.
#22 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
Posted 15 August 2013 - 04:17 PM
just for the record, your monitoring solution is connected directly to the UX?
#23 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 15 August 2013 - 04:18 PM
You'd be surprised how much i actually get done...
i'm a multi-tasking ninja  :ph34r:
Probably support close to 2000 clients everyday!
telecommuting has it;s benefits.
#24 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:30 PM
alright so I'm obviously using the wrong asio, I tried the "full duplex driver" because no one explained the one to use, and that seemed to work a little for me, so just mono all the sends or set them up in stereo or set up a few in stereo and a few in mono, do you know what sends go to what ports? as in 1-2 are used for guitar port and 3-4 are used for mic port? giving this a shot
#25 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
Looking at your screen shot, it may be the Digital Audio In
#26 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:34 PM
ok so now I got the mic working, but it will not record audio which I just tried, and for some reason I get nothing. but I can hear the mic working so woot! almost there. but it seems the sends  are only used for the mic when I checked them out in control pannel
#27 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:36 PM
that was only for guitar for some strange reason, like I said In control pannel only the mics were listed as the sends.
#28 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:39 PM
got it to work, you can't have the mic armed to listen when you play a recording back...even though you can for guitar...sweet deal. so everytime I want to use the mic I just change it to this and I can use it and for guitar I change it back to "full duplex driver"
#29 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
Posted 15 August 2013 - 04:57 PM
That makes sense.
#30 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 06:20 PM
but now when I switch over the mic is the only thing that works...this is not good, I can't get it to switch over to the guitar at all and the digital audio interface only uses the mic now... I tried unplugging it to no avail, and I am unsure what else to do to get it to work....this is just getting worse and worse.
#31 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
Posted 15 August 2013 - 07:11 PM
Are you selecting "Instrument" in POD Farm?
Cubase can not select the UX input, it can only select from the availble sends from POD Farm..
#32 deepseahunter
deepseahunter
  • 22 posts
Posted 16 August 2013 - 06:38 AM
No I have to go into control panel in the in device setup>vts audiosystem> ASIO ux1 and change the inputs & recording input to instrument from mic, it's preset is the mic, but I got it figured out. It doesn't allow me to change it in pod farm actually which is change the input that way, which is less easy but whatever still works the same.
#33 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7368 posts
Posted 16 August 2013 - 08:32 AM
Are you mixing up POD FDarm Standalone with the plug-in, you can not select instrument or mic in the plug-in.
If you launch POD Farm outside of Cubase it is the stand alone and you should be able to select Instrument or Mic.
Also tagged with one or more of these keywords: pod farm, mic failure, no audio, ux1
