No Audio While Trying To Record With Mic In Cubase And Podfarm Or Just Messing Around In Pod Farm 2.5
pod farm mic failure no audio ux1
32 replies to this topic
#21 Triryche
Triryche
    Guru
  • Line 6 Expert
  • 4577 posts
Posted 15 August 2013 - 04:16 PM
Do you have monitoring turn on in Cubase? Typically you should not.
#22 Triryche
Triryche
    Guru
  • Line 6 Expert
  • 4577 posts
Posted 15 August 2013 - 04:17 PM
just for the record, your monitoring solution is connected directly to the UX?
#23 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 14880 posts
  • LocationClemmons, NC USA
Posted 15 August 2013 - 04:18 PM
You'd be surprised how much i actually get done...
i'm a multi-tasking ninja  :ph34r:
Probably support close to 2000 clients everyday!
telecommuting has it;s benefits.
Can you please elaborate on this?
btw, Zap IS a support guy, I've seen him support a wall ALL DAY LONG!!  :lol:
not really, but I'm cracking myself up nonetheless!!
#24 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:30 PM
The sends are in POD Farm's mixer view.
I haven't used Cubase in years, so it might be called something different.
For example, in Reaper I select Line6 ASIO as my device and enable all 4 sends in the prefences.
Then when I arm a track to record I have available mono input 1,2,3, or 4 or stereo 1-2, 2-3, 3-4.
Clear as mud, right?
So it may be Cubase names them something else.
alright so I'm obviously using the wrong asio, I tried the "full duplex driver" because no one explained the one to use, and that seemed to work a little for me, so just mono all the sends or set them up in stereo or set up a few in stereo and a few in mono, do you know what sends go to what ports? as in 1-2 are used for guitar port and 3-4 are used for mic port? giving this a shot
#25 Triryche
Triryche
    Guru
  • Line 6 Expert
  • 4577 posts
Looking at your screen shot, it may be the Digital Audio In
#26 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:34 PM
ok so now I got the mic working, but it will not record audio which I just tried, and for some reason I get nothing. but I can hear the mic working so woot! almost there. but it seems the sends  are only used for the mic when I checked them out in control pannel
#27 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:36 PM
that was only for guitar for some strange reason, like I said In control pannel only the mics were listed as the sends.
#28 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 04:39 PM
got it to work, you can't have the mic armed to listen when you play a recording back...even though you can for guitar...sweet deal. so everytime I want to use the mic I just change it to this and I can use it and for guitar I change it back to "full duplex driver"
#29 Triryche
Triryche
    Guru
  • Line 6 Expert
  • 4577 posts
Posted 15 August 2013 - 04:57 PM
That makes sense.
#30 deepseahunter
deepseahunter
  • 22 posts
Posted 15 August 2013 - 06:20 PM
but now when I switch over the mic is the only thing that works...this is not good, I can't get it to switch over to the guitar at all and the digital audio interface only uses the mic now... I tried unplugging it to no avail, and I am unsure what else to do to get it to work....this is just getting worse and worse.
#31 Triryche
Triryche
    Guru
  • Line 6 Expert
  • 4577 posts
Posted 15 August 2013 - 07:11 PM
Are you selecting "Instrument" in POD Farm?
Cubase can not select the UX input, it can only select from the availble sends from POD Farm..
#32 deepseahunter
deepseahunter
  • 22 posts
Posted 16 August 2013 - 06:38 AM
No I have to go into control panel in the in device setup>vts audiosystem> ASIO ux1 and change the inputs & recording input to instrument from mic, it's preset is the mic, but I got it figured out. It doesn't allow me to change it in pod farm actually which is change the input that way, which is less easy but whatever still works the same.
#33 Triryche
Triryche
    Guru
  • Line 6 Expert
  • 4577 posts
Posted 16 August 2013 - 08:32 AM
Are you mixing up POD FDarm Standalone with the plug-in, you can not select instrument or mic in the plug-in.
If you launch POD Farm outside of Cubase it is the stand alone and you should be able to select Instrument or Mic.
Also tagged with one or more of these keywords: pod farm, mic failure, no audio, ux1
