Pod Hd500x Sounding Thin Compared To Hd500
pod hd500x
26 replies to this topic
#1 matthewterrado
matthewterrado
  • 21 posts
  • Registered Products:3
Posted 15 August 2013 - 08:56 AM
I recently upgraded to the POD HD500x from the HD500 and uploaded my old tones from the 500 to the 500x by changing the .extension. It worked great except I've noticed that my tone sounds thinner and brighter on the HD500x. Also, it seems like the output volume is quieter while using headphones than it was on the 500. Any Ideas?
#2 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
  • Registered Products:2
Posted 15 August 2013 - 09:07 AM
Are your input/output settings the same? Studio/ direct vs combo front etc? Global input options? Impedance?
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17810 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 15 August 2013 - 09:08 AM
your bundle/tones do not have your global settings.. perhaps there is a difference there?
#4 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 464 posts
  • LocationArizona, U.S.A.
  • Registered Products:4
Posted 15 August 2013 - 09:09 AM
Assuming you are correct you could do a manual comparison (maybe via screenshots) whether the tone settings in the file (the binary encoding) are translating to the same parameter values (what shown in the SW editor or on the HD display) on the HD500 and HD500X user interfaces.
You should be able to at least check and compare the 2 editors using both file versions of the 'same' tone if you do not have the HD500 anymore. Would be really interresting if you find a difference beyond it just sounding different.
Besides that there could be more HW changes lurking that have not been dicovered by users opening the HD500X enclosure (and not pulished by Line 6), e.g., like a change in AD converters or just a later rev of the AD converters installed in the HD500X.
Just wildly guessing ...
Martin
#5 matthewterrado
matthewterrado
  • 21 posts
Posted 15 August 2013 - 10:37 AM
I sold my 500 to a friend but he said he'll give it back to me so I can compare the two. I'll let you guys know what I find. Thanks for responding!
#6 matthewterrado
matthewterrado
  • 21 posts
Posted 25 August 2013 - 08:52 AM
So I compared the two and the Hd500 is louder than the 500x but the tones are pretty consistent between the two. Maybe my ears were messing with me on the day I first got the 500x!
#7 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 293 posts
  • Registered Products:5
Posted 26 August 2013 - 11:06 AM
Tones can sound different at different volumes.  It's called the Fletcher Munson Curve:  http://en.wikipedia....r–Munson_curves
If there was a noticeable difference in volume the patch could have sounded thin as you wouldn't hear as much bottom end.  So it may not have been your ears messing with you!
I remember they added a loudness feature to the Vetta, firmware 2.0 I believe, that compensated for this when you were playing at lower volumes.
Feature wise the Vetta was way ahead of its time.  That was a sweet amp, but way heavier than my HD500 :)
  • 1
#8 matthewterrado
matthewterrado
  • 21 posts
Posted 27 August 2013 - 07:30 AM
That totally makes sense! My question now is, should I set my master volume lower while running the POD direct out in the PA so I can get the bottom end?
#9 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 293 posts
Posted 27 August 2013 - 08:26 AM
What I do is leave the master volume on the HD500 wide open.  I then create my patches at whatever volume, and as close to the same speaker type, I'll be using onstage.  That way I know pretty much what I'm going to get.
Then if you find that you're having to play at a lower volume at a gig and it sounds a little thin you can use the EQ on the PA to compensate.  That way you aren't going back and adjusting all your patches.
I pretty much only play going direct to the house these days and use a stage monitor or in ear monitors.  This method of creating patches works really well for me.
Also if you use the same PA or setup a lot you can start to figure out how it reacts.  I have a PA that I own and use and it tends to produce a little more bottom end, so I create the patches that way.  I have another set of patches I use if I play at church because I'm familiar with how the room reacts.
  • 1
#10 matthewterrado
matthewterrado
  • 21 posts
Posted 27 August 2013 - 09:02 AM
Yeah I create my tone using my IEMs, so opening up the master volume would kill me. I suppose I can turn the amp or mixer volume down to open up room for the master. It doesn't sound thin at lower volumes. It's when you crank it that it starts to sound thin. I'll try your method out! Thanks for the help!
#11 scottyo78
scottyo78
    Iknowathingortwo
  • PipPip
  • 240 posts
  • LocationSeattle, WA
Posted 27 August 2013 - 02:55 PM
Really? Wow. That just goes to prove the "Different strokes for different folks" moniker. ^_^
When I create my tones... all of them... through each system, favor the bass/mid's when I crank it. :D
At home I play through my studio (KRK Rokit 8's) or my 1/2 stack. At church, the PA and/or sometimes my Fender Stage 112 amp.
#12 DeanDinosaur
DeanDinosaur
    Gear Head
  • PipPipPip
  • 757 posts
Posted 27 August 2013 - 03:23 PM
I believe you get the best signal to noise ratio with master volume for the whole unit at 10 (the actual physical knob, not the amp master volume).
#13 matthewterrado
matthewterrado
  • 21 posts
Posted 27 August 2013 - 06:40 PM
Do you mean 10 o'clock or 10 (100%)?
#14 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 293 posts
Posted 27 August 2013 - 06:54 PM
I believe he meant 100%
#15 DeanDinosaur
DeanDinosaur
    Gear Head
  • PipPipPip
  • 757 posts
Posted 28 August 2013 - 06:16 AM
Yes I meant 100%.
  • 1
#16 matthewterrado
matthewterrado
  • 21 posts
Posted 28 August 2013 - 06:40 AM
Yes I meant 100%.
Yeah I used to run my hd500 at 100%. I'm gonna try chuskey's method of shaping tone with the master at 100% with the 500x.
#17 Jonam93
Jonam93
  • 1 posts
Posted 22 October 2013 - 08:06 AM
I don't know how to start a new topic on here, but I'm having real issues with my HD500x looper and can't find any advice on the web about it:
The looper is meant to be 48 seconds. but it's not even doing half that before stopping recording me and starting again from the beginning, just as if I'd pressed the footswitch.
Has anyone else had this problem?
#18 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9043 posts
  • LocationMinneapolis, MN
Posted 22 October 2013 - 08:14 AM
The looper time can be extended to 48 seconds if you hit the half speed switch prior to recording your loop.
#19 Karl_Houseknecht
Karl_Houseknecht
    Guru
  • PipPipPipPipPip
  • 4039 posts
Posted 22 October 2013 - 08:29 AM
I always set the master volume of the HD to 50%.  Because if my sound guy tells me he needs more or less signal, then I can adjust as needed.  If it's at 100% and he needs more, then I'm screwed.
  • 2
Guitars: Schecter C-1 Custom FR, Wolfgang Special, American Elite Strat, American Elite Tele, Swirl Tele, Veritas Portlander
Amps & Effects: Helix, Kemper Power Head, Marshall DSL40C
#20 subinmathews
subinmathews
  • 1 posts
  • LocationBangalore, India
Posted 04 November 2014 - 09:17 PM
Hey,
After a long wait i finally got my hands on the POD HD 500X
Tried using the looper function. There is a delay (Empty space) between the loops.
Is there some setting tweeks i need to figure out? or is there an issue with the gear?
Thanks
#21 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17810 posts
Posted 05 November 2014 - 03:47 AM
it's all in the timing...  it's something you'll have to work at.
Hey,
Thanks
  • 1
#22 robertmcollins3
robertmcollins3
  • 83 posts
Posted 05 November 2014 - 07:57 AM
Yep, this happens if you don't hit the record button at just the right time.  Took me a long time to figure this out when I first started using a looper.
In SIMPLE terms, if your progression is for example G, C, D.  Play it once or twice without the looper, then hit the record for the first time just as you hit the G chord, then again when you get BACK to the G chord again.  You are likely hitting it on the D instead...or something similar.  There are several youtube videos that explain it better, but that was my issue anyway.
#23 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
  • Registered Products:8
Posted 05 November 2014 - 08:32 AM
IMO the HD looper is "ok" and there are some neat things that can be done with it but it really needs to be able to quantize  (ie: fill in the gaps). So if you ever get the urge to look for an external looper remember that term.
-B
Smell the glove.
#24 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17810 posts
Posted 05 November 2014 - 10:03 AM
exactly... that and a number of other features is why i bought a RC300
crazy overkill, and crazy big.. but crazy awesome! :)
-B
#25 robertmcollins3
robertmcollins3
  • 83 posts
Posted 05 November 2014 - 03:13 PM
I like the looper, but maybe I'm doing something wrong with it...
I get a loop going just fine, but it seems any effect I turn on (like distortion or delay) gets applied to the loop.  So if I want to lay down a clean backing track, or a delay loop, and play some lead with distortion, the distortion automatically gets applied to the backing track, which usually ends up sounding horrible.
#26 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17810 posts
Posted 05 November 2014 - 03:23 PM
you need to change the pre/post setting based on which one you want at the time,.
#27 robertmcollins3
robertmcollins3
  • 83 posts
Posted 05 November 2014 - 03:36 PM
Thanks, just figured that out as well but it was too late to edit the post!
Also tagged with one or more of these keywords: pod hd500x
