Now Available: Variax Hd Upgrade And Workbench Hd Software
422 replies to this topic
#41 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 15 August 2013 - 12:24 PM
same model = same tone
Sorry, i mean the tone not the model
#42 floyd25
floyd25
  • 15 posts
  • Registered Products:2
Honestly, everybody is starting to guess what line6 changed with this HD update. They give us this marketing message but what they should do is: just list what they did change. Somebody said the 12 string sounds better, another one said they didn't update them. So?
#43 anthonylee
anthonylee
  • 50 posts
  • LocationIsrael
  • Registered Products:3
Posted 15 August 2013 - 12:27 PM
if you mean workbench... its not reinstalling them, it resyncs them.
but now i have nothing working
#44 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 August 2013 - 12:28 PM
You're assuming he meant the 12 string acoustics....  he was probably saying the 12 string ricks... since they had been discussed recently.
#45 anthonylee
anthonylee
  • 50 posts
  • LocationIsrael
Posted 15 August 2013 - 12:31 PM
updated flash memory no sound
#46 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 August 2013 - 12:32 PM
maybe try flashing down first to 1.8?
only a guess... never seen this one.
#47 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 12:35 PM
all models except the acoustic had some change in tone? is it?
Jtv 69 , pod hd 500x, suhr S3,, Gibson SG standard 96, fender plus strat 93, les paul custom 96
#48 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 August 2013 - 12:40 PM
not a change in tone... a change in model... which yes results in a change of tone... (but the tone wasn't altered from the previous model... those models were removed)
#49 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 August 2013 - 12:44 PM
you also HAVE to make sure that you overwrite the old models when it warns you...
if you try to keep your models, that could cause issues...
(not sure if this is a factor in your issue... but worth mentioning)
#50 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 12:46 PM
thankls ,last question why the website only mentions the JTV 59? just something special with it?
#51 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 August 2013 - 12:49 PM
I didn't see any specific reference to the 59:
http://line6.com/news/general/1433
it applies to all James Tyler Variaxes.
#52 anthonylee
anthonylee
  • 50 posts
  • LocationIsrael
Posted 15 August 2013 - 12:53 PM
flashed down to 1.82 works /try again
#53 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 12:54 PM
I know that ,im talking about that http://line6.com/jtv-59/features  , in the ultimate guitar recording- with variax HD, it speaks only of 59, but I think it is only an example right?
in features
#54 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 August 2013 - 12:57 PM
I see what you're saying now... I'm confident it's just a typo/error.
#55 anthonylee
anthonylee
  • 50 posts
  • LocationIsrael
Posted 15 August 2013 - 12:59 PM
flashed to 2.0 now works. ThanX :-)
#56 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 01:02 PM
I wondered that too
#57 andiw
andiw
  • 15 posts
  • LocationBerlin, Germany
  • Registered Products:4
Posted 15 August 2013 - 01:09 PM
Just flashed to V2. The models feel better. Seems there's less latency ... I like it so far!  :)
#58 karmicfreak
karmicfreak
  • 92 posts
Posted 15 August 2013 - 01:17 PM
Updated... with some trouble.  Tried to do the Vax 2.0, and it failed, crashed my mac 1/2 thru.  It showed 2.0 was loaded, but it only had the teles and strats.  I was able to re-do the update after a couple more tries.  My HD500 needed updating, as well as Monkey.  I had several kernel-panic type crashes on my 2011 iMac i5 with 8GB memory... shouldn't have happened.  I couldn't update the variax or the HD the first time... I'm going to recommend this order for HD500/JTV users like me for those who haven't updated yet (please chime in if you disagree!)
Log onto HD500 Edit, save all your presets.  Do this before you update HD500 edit!
Update L6 Monkey
Update HD500 driver
Update HD500 firmware
Connect the Variax via the USB interface and plug a 1/4" cable in to turn it on.
Open Workbench and save any custom models
Run L6 Monkey, update Workbench
Update Variax to 2.0
Hope you can avoid my troubles.  The models seem a little more... present?  Especially the Teles, to my ears.  The Gretsches seem different also, but those are my most-used models.   Was this worth 8 months?  Maybe.  Workbench is pretty cool, but only so usable until it can work thru the HD500.
#59 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 01:19 PM
aaaah THX that solved my problem!! I think that Information should be found in Workbench HD
the Jtv should have the battery or not? , My interface is still flashing red side of the cable vdi. Thanks
#60 johnnyayyy
johnnyayyy
    Power User
  • PipPipPipPip
  • 1377 posts
Posted 15 August 2013 - 01:21 PM
First impressions... hmmmmm... the guitar seems more sensitive to finger noise, especially right hand fingestyle/travis picking - it is like the pickups are suddenly more microphonic (I realize this is impossible but that is the best way to describe what I am hearing). This is on patches created specifically for Variax so some adjustment in HD500 and in playing technique will probably be needed.
Same on patches made for a real Strat when using the Spank models - Travis picking sounds like a box of spoons dropping every time my picking fingers touch and release the strings.
I am also noticing more warbling on the Rick 12 strings than before, like I have to be super careful to avoid the open G string going haywire and sounding what sounds like a half step off. Also some slight fret buzz on the low E that was not an issue before (I never noticed it at all until today) sounds horrid now - need to tweak my truss rod I think.
Hopefully everyone else will have a better first go at it than I am. From what I can tell (aside from the buzzing and heavy warbling on the Rick 12) the modeling sounds good, I am noticing a big improvement in the R-Billy bank especially. I am going to do some A/B recording tests next week with my Variax Transplant and see just how different the tones are - until the update my JTV sounded pretty much exactly like the Tele.
Hmmm, also when switching models on the guitar it seems to switch slowly with a silence in between models, but if I switch models using the controls on the HD500 switching seems quicker with no dropout in sound. I only use my JTV for recording so it is not a problem but this might be a pain for anyone playing live.
I think tonight I will  try reflashing and see if that clears up any of these issues.
#61 jefflynyrd
jefflynyrd
  • 80 posts
Posted 15 August 2013 - 01:51 PM
I noticed same things as johnnyayyy...I think I need to raise my bridge a touch as my action is set very low... I did notice it (b and e strings not ringing out as they should) before update but it wasn't as noticeable... Still very happy n smiling!
#62 toasterdude
toasterdude
    Gear Head
  • PipPipPip
  • 978 posts
  • Locationsanto domingo
  • Registered Products:10
Posted 15 August 2013 - 02:04 PM
There only appears to be one tele body now and not 3? Wide range buckers and dog ear p90s are a welcome addition. Never had a guitar with wide range buckers. The variax will let me try it out.
To clarify... the tele was just modeled from a different model than the old models...
but yes... all of the new models sound way more dynamic... and the difference between the models is now alot more noticeable IMO
#63 just-joshin-ya
just-joshin-ya
  • 32 posts
Posted 15 August 2013 - 02:10 PM
I can't get the workbench to download? It says page is unavailable for it and the new version of monkey any ideas?
#64 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
Posted 15 August 2013 - 02:18 PM
Hey buds, once you guys have some fun, can you guys share some demos?
For a minute there, I lost myself.
#65 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 15 August 2013 - 02:28 PM
Yes, it should have the battery installed.  You should also plug a cable into the 1/4" jack, since the Variax USB interface will not power the guitar.
#66 lindsayward
lindsayward
    Iknowathingortwo
  • PipPip
  • 171 posts
  • LocationTownsville, Australia
Posted 15 August 2013 - 03:23 PM
I have updated and like it overall - especially the telecaster, and I think I'll be using the Les Paul (neck) a lot more than before :)
HOWEVER, one of my favourite and most-used models is the Jazzbox-4 (neck + middle position), and it sounds vastly different to me! I don't like it as much as the first one. This one has kind of a duller main tone with a beady, narrow kind of string tone - not as even and sweet as the last one. Not "bad", but not what I want - not compared to the previous model.
Anyone got any thoughts on this model?
#67 KennyMac
KennyMac
  • 12 posts
  • LocationEscondido, CA
Posted 15 August 2013 - 03:27 PM
I've created a chart of the different guitars. You can download it here: https://dl.dropboxus...57/Variaxes.pdf
  • 1
#68 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 August 2013 - 03:35 PM
it doesn't reflect the tele changes...
but i've always been partial to this visual version:
  • 5
#69 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 03:46 PM
HOWEVER, one of my favourite and most-used models is the Jazzbox-4 (nexk + middle position), and it sounds vastly different to me! I don't like it as much as the first one. This one has kind of a duller main tone with a beady, narrow kind of string tone - not as even and sweet as the last one. Not "bad", but not what I want - not compared to the previous model.
yes i think the same way, it seems that before had more bass, more depth
#70 fr0sty
fr0sty
    Iknowathingortwo
  • PipPip
  • 114 posts
  • Registered Products:5
Posted 15 August 2013 - 05:05 PM
Thanks for the new jtv update.
#71 LarryLion
LarryLion
    Iknowathingortwo
  • PipPip
  • 143 posts
  • LocationCaledon, Ontario
Posted 15 August 2013 - 05:10 PM
I'm using a Mac and immediately noticed that if I click on "Open Preset Folder" in WB-HD, I get an error.  Anyone get the same message? I searched thru the helpfile PDF, no clues there.
Larry d'Lion
2012 Line 6 JTV-69
Plus lots of Tele's, Gretsches,
Mesa Boogie amps, Fender Blues Jr.,
... and lots of acoustic stuff
#72 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 05:16 PM
when I click on the workbench  in parallel pitch and in preset nothing appears, someone already knows how it works?
#73 jeffgtr60
jeffgtr60
  • 4 posts
Posted 15 August 2013 - 05:26 PM
I updated to the jvt59 firmware, updated the audio/midi driver, updated monkey, installed hd workbench.
Everything went swimmingly EXCEPT the HD Workbench cannot find the Variax. I've tried connecting using the HD500 and the interface that came with the Variax. Still didn't work. I've rebooted, reinstalled HD Workbench..nothing.
The Old Workbench connects just fine and recognizes the guitar.
I know the firmware installed because the difference in the models is noticable.
I'm running a Macbook Pro 2.2GHZ I7 16GB Ram, Mountain Lion, I do have Logic X installed and use a Focusrite interface, however that shouldn't have anything to do with it.
Any ideas? I'm out of them.
#74 spikey
spikey
    Power User
  • PipPipPipPip
  • 2447 posts
  • LocationUSA
  • Registered Products:8
Posted 15 August 2013 - 05:39 PM
you can use the 500, 500x, or pro (or pretty much any variax enabled pod) to update... only workbench has the issue.
Not that I dont appreciate the new software but...., I "want" to use my $700 HD Pro and workbench HD together in realtime to hear the changes made thru the patches in the HD Pro. Not thru a cheap plastic interface. I hope they fix this sooner than later...
I've used everything in Helix, but then I'm not from this planet ...    :lol:
#75 spikey
spikey
    Power User
  • PipPipPipPip
  • 2447 posts
  • LocationUSA
Posted 15 August 2013 - 05:41 PM
Very nice and THANKS!!!!!
#76 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 August 2013 - 05:54 PM
Thanks
#77 McLenison
McLenison
  • 99 posts
Posted 15 August 2013 - 06:10 PM
Not sure if I uploaded it properly.  Here's what happened:
I click OK and it starts loading
Then this next screen occurs.  Was it successful?
#78 spikey
spikey
    Power User
  • PipPipPipPip
  • 2447 posts
  • LocationUSA
Posted 15 August 2013 - 06:14 PM
Well thats the old workbench, and it shows that your Variax is not at 2.0... The new workbench HD looks much different.
#79 jeffgtr60
jeffgtr60
  • 4 posts
Posted 15 August 2013 - 06:29 PM
I posted earlier I couldn't get hd workbench to recognize my guitar. Not sure what I did differently but it finally connected. I was using the usb interface instead of the hd500
#80 Jasonbrianmerrill
Jasonbrianmerrill
    Iknowathingortwo
  • PipPip
  • 148 posts
Posted 15 August 2013 - 07:19 PM
for some ridiculous reason, they made it so you can no longer connect through the pod. hope no one sold their workbench interface (like I almost did!!)
  • 1
