Hd500x Usb Feedback
8 replies to this topic
#1 Gunslinger_11
Gunslinger_11
  • 19 posts
  • Registered Products:4
Posted 15 August 2013 - 05:16 PM
I am getting an annoying hum through my amp when I attach my HD500x to my computer through USB.  My HD500 was quiet as heck, and I just swapped in my new 500x and the hum appeared.  when I unplug the USB the hum subsides.  Any ideas on how to eliminate this?
#2 Gunslinger_11
Gunslinger_11
  • 19 posts
Posted 16 August 2013 - 07:35 AM
This is some sore of ground loop form the computer.  Can anyone recommend a good ground loop eliminator.  I know Bheranger and EBtech make them.
I think it is comming form the computer side, so woudl a Hum-X plug adapter from EBtech work well?
#3 Gunslinger_11
Gunslinger_11
  • 19 posts
Posted 20 August 2013 - 09:33 AM
I picked up a ground loop eliminator and it works!  no more humm whatsoever!!  The DT25 and the 500x are quiet even in the tredplate setting (iv).
Thanks for the help with this..  Not...
G
#4 talwilkins
talwilkins
    Iknowathingortwo
  • PipPip
  • 458 posts
  • LocationNetherlands
  • Registered Products:6
Posted 20 August 2013 - 02:21 PM
I'm sorry nobody could help you out.
Could you tell me which ground loop eliminator you got?
Information is not knowledge. Knowledge is not wisdom.
Wisdom is not truth. Truth is not beauty.
Beauty is not love. Love is not music.
Music is THE BEST (Frank Zappa)
#5 Gunslinger_11
Gunslinger_11
  • 19 posts
Posted 20 August 2013 - 04:29 PM
I picked up the Behringer Micro HD400 - killed the hum right away (it was the cheapest solution at $34) installed between the HD500x 1.4 out and the amp..  I am going to also get the EBTech Hum-X  which plugs into the outlet as I have my computer on a different circuit than the amps.
I picked up the Micro HD400 at canadacomputers.com in Markham Ontario.
Hope that helps.
#6 talwilkins
talwilkins
    Iknowathingortwo
  • PipPip
  • 458 posts
Posted 21 August 2013 - 04:04 AM
How would this work with the DT-25 HD500 combination?
#7 Gunslinger_11
Gunslinger_11
  • 19 posts
Posted 21 August 2013 - 05:25 AM
It will be the same for the DT25 HD500.   Just place the box between the HD500 and the amp.  So from the 1/4 inch (Left) on the HD 500, connect a short 1/4" patch cable to input #1 on the Micro HD400, connect your one end of the guitar cable to output #1 of the Micro HD400 and to the other end to DT25 front input.  You can place the box between any gear that is creating  a ground loop.
This killed the hum on the signal to the amp.  I still have a bit of a hum from ambient interference from my computer but it is barely audible - I think the EBtech Hum-X attached to the computer power main will solve that.
I would post a pic of my setup, but I don't know how.
#8 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17846 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 21 August 2013 - 05:29 AM
you don't use the 1/4" for DT amps (typically) you'd use the L6LINK (digital xlr)
not sure if this product would be suitable for this purpose... (or that the hum would reside in the same place, being that the amp is fed digitally)
#9 Gunslinger_11
Gunslinger_11
  • 19 posts
Posted 21 August 2013 - 05:45 AM
I do and I am using the product for this purpose.  its a passive box so it does not colour  your tone in any way.
I agree that using the L6Link the sound is pure (no hum), but when I record I typically go through the front input (because I like the sound it produces), and with the USB cable plugged in to the HD500x, I was getting a tremendous hum in the DT25 which is not good for recording.  I found using this box in the signal path as I described above eliminated the hum coming out of the amp with no side effect to sound quality.
