Dtothe8 Posted May 1, 2016 Share Posted May 1, 2016 Hi, I was wondering about how I can record with the AMPLIFi 30, I'm going to buy. There's no output! I can use the headphones output, of course. But....... On the quickstart manual it's written the USB input is for future use........ may somebody help me, please? thanks a lot for any answer Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted May 1, 2016 Share Posted May 1, 2016 Can record now from USB to Mac etc. Was an update to allow this sometime ago. 1 Quote Link to comment Share on other sites More sharing options...
Dtothe8 Posted May 1, 2016 Author Share Posted May 1, 2016 that's good news, Gkf9. I work on Cubase or Reason on pc with windows 7 or 10. do you know if and how they can recognize the input? thanks a lot anyway for the answer! Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted May 1, 2016 Share Posted May 1, 2016 I'm not to sure to be honest, I'm relatively new to the Amplifi myself. I just know that I've come across threads on here about the same thing. I'm sure someone else with more knowledge will answer shortly. Or maybe try the search button in the meantime. Quote Link to comment Share on other sites More sharing options...
Dtothe8 Posted May 1, 2016 Author Share Posted May 1, 2016 I've tried. Anyway, I've directly opened a ticket at the Support. I will share the answer here. Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 2, 2016 Share Posted May 2, 2016 On a PC it will act as an ASIO device. 1 Quote Link to comment Share on other sites More sharing options...
Dtothe8 Posted May 2, 2016 Author Share Posted May 2, 2016 thanks, Uber Guru! then, it will not interfere with the asio driver of my USB audio interface (Steinberg UR22)? it will be just another one on the inputs window? so the USB is now officially an output? Do I have to take care to buy a new AMPLIFi 30 or it will just be needed to update it? excuse me for all the questions but you're an expert. I take the chance ;) thanks again! Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 2, 2016 Share Posted May 2, 2016 It should not interfere with your Steinberg UR22’s drivers, however, with ASIO you can only use one device at a time. Not sure which firmware they are shipping with, but if it is not current you just need to update it. Best would be to check the return policy just in case you aren’t happy with the AMPLIFi. 1 Quote Link to comment Share on other sites More sharing options...
jdebiase Posted May 3, 2016 Share Posted May 3, 2016 It should not interfere with your Steinberg UR22’s drivers, however, with ASIO you can only use one device at a time. Not sure which firmware they are shipping with, but if it is not current you just need to update it. Best would be to check the return policy just in case you aren’t happy with the AMPLIFi. Hi. I cannot get my Mac to recognize my amplifi 75. I'd like to play around with some tracks, specifically in Garage Band. Many posts and on line videos state that you just hook up the amp to your computer using usb, which I did and the Mac and Garage Band automatically sees there is a device. But it is only reading the sound from the internal mic. Any suggestions? Thanks Jim Quote Link to comment Share on other sites More sharing options...
chromefabric Posted May 4, 2016 Share Posted May 4, 2016 You have to download the driver for Windows. Mac doesn't need a driver. When you connect the Amplifi to your computer the Amplifi becomes your audio interface. You can hear whatever is playing back from your DAW as well as the input from the guitar. Quote Link to comment Share on other sites More sharing options...
jdebiase Posted May 4, 2016 Share Posted May 4, 2016 You have to download the driver for Windows. Mac doesn't need a driver. When you connect the Amplifi to your computer the Amplifi becomes your audio interface. You can hear whatever is playing back from your DAW as well as the input from the guitar.The problem is my Mac does not recognize any new audio interface when I hook up the Amplifi. So what should I do?Jim Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 4, 2016 Share Posted May 4, 2016 What version firmware is on the AMPLIFi Quote Link to comment Share on other sites More sharing options...
jdebiase Posted May 4, 2016 Share Posted May 4, 2016 What version firmware is on the AMPLIFi Hi It says the Flash is 2.50.2 Quote Link to comment Share on other sites More sharing options...
chromefabric Posted May 5, 2016 Share Posted May 5, 2016 I'm not sure but it could be the version of MacOS you are using. It has to be MacOSX 10.7 or above. Quote Link to comment Share on other sites More sharing options...
jdebiase Posted May 5, 2016 Share Posted May 5, 2016 I'm not sure but it could be the version of MacOS you are using. It has to be MacOSX 10.7 or above.I'm using El Capitan it's the newest OS they make! I've tried 2 cables, both work fine on other devices and I've tried connecting to 3 different USB ports on the computer itself! Nothing. Line 6 asked the same questions but no real solution!Jim Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 6, 2016 Share Posted May 6, 2016 Not a Mac guy, so not sure how audio devices show up. Quote Link to comment Share on other sites More sharing options...
