PDKTDK Posted May 1, 2016 Share Posted May 1, 2016 I played it today at my gig as I normally do. Came home and plugged it in and the screen lit up for a second and went dead. I tried different outlets. It did the same thing one more time. Now it appears to just be dead I did notice the green light is not illuminating on the power supply. Does the power supply only light up when connected to a working HD500 or is it always lit when plugged into power? This would make the solution obvious... as well as less costly. Thanks. Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted May 1, 2016 Share Posted May 1, 2016 It is always lit. Only time I recognized this behavior was after putting an extension to the original cable. 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted May 1, 2016 Share Posted May 1, 2016 Even if the power supply is connected to power and not connected to the HD, the light still lights. So it does sound like the power supply is kaput. You could try one of these: http://www.trcelectronics.com/View/Mean-Well/GSM36B09-P1J.shtml But I remember coming across some info on this forum about the output connector for this supply being slightly different in size. Might want to search for that to be sure. 1 Quote Link to comment Share on other sites More sharing options...
PDKTDK Posted May 1, 2016 Author Share Posted May 1, 2016 Thanks peeps! I can't wait for shipping. GC has it in stock for $28 USD. Much appreciation for this always supportive community. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 2, 2016 Share Posted May 2, 2016 Even if the power supply is connected to power and not connected to the HD, the light still lights. So it does sound like the power supply is kaput. You could try one of these: http://www.trcelectronics.com/View/Mean-Well/GSM36B09-P1J.shtml But I remember coming across some info on this forum about the output connector for this supply being slightly different in size. Might want to search for that to be sure. This is true. I posted this awhile ago WARNING:WARNING. This won't work. I know according to the specs the "hole" on the connector is 2.1mm but this is WRONG!!!. 2.1mm is too small. I wasted $20 finding this out. The correct measurment is 2.5mm not 2.1mm. I was trying to get an elbow adapter for the 500 and the 2.1 didn't work. The specific measurements were. 5.5 X 2.5. This is what I got. BiXPower LC53 Right Angle Connector Converter for 5.5 x 2.5mm DC Power Connector This size worked. I don't know why their measurements are so off. So if you got that power supply, you would need a 2.1mm-2.5mm barrel to convert it too the proper size. 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted May 2, 2016 Share Posted May 2, 2016 Thanks brue58ski. Quote Link to comment Share on other sites More sharing options...
