Pod Hd 500 - 500x *new* Routing Schematics
routing signal routing effect block gain input settings hd500 hd500x mono summing unity gain
82 replies to this topic
#41 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
  • Registered Products:3
Posted 24 December 2013 - 04:54 AM
We might be hijacking the thread,
here is the thread on using both xlr and jack for mono or stereo setups:
http://line6.com/sup...ut-and-xlr-out/
#42 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 24 December 2013 - 08:49 AM
I posted a new topic about the Input Settings "Phase Issue" and the choice between a single input active (e.g. guitar/variax) or both inputs active (guitar/guitar),
here it is:
http://line6.com/sup...-vs-both-inputs
#43 cz-milan
cz-milan
  • 18 posts
  • Registered Products:5
Posted 25 December 2013 - 04:22 AM
Hello Lorenzo,
I think, it would be better that you will make a hand sketch and present it here. I will redraw the scheme then.
Thanks for your wishes, I wish you the same, merry Christmas time and pleasant relax.
You can quote me as Milan, Line 6 fan and Line 6 manuals´ translator into Czech language.
Milan
#44 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 25 December 2013 - 03:22 PM
Hello Lorenzo,
Milan
Thanks to you, Milan, I started modifying my schematics and ended up with a version I like A LOT!
you can redraw your version and publish it, but I think that here I'll stick with this handmade version at least for a while
bye
and happy new year!
Lorenzo
#45 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 25 December 2013 - 03:28 PM
I updated my routing schematics
the mods do not concern the content of the routing
It's just a clearer way to explain the same signal routing
many thanks to Milan, Line 6 fan and Line 6 manuals' translator into Czech language
for inspiring me in doing that
cheers
Lorenzo
#46 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
  • Registered Products:2
Posted 29 January 2014 - 08:38 AM
Any info for use withta dt25/50 amp? dual paths, cab modelling, the point in the chain where channel volume and master volumes are placed,and summing etcwhen output is unexplained with a line6 link to a dt25 amp..
Especially when low volume gets engaged, and the use of the direct out. whats going on in the chain there is a total mystery, and I've received conflicting explanations the few times I asked line6 support, so I guess they don't understand it either.
#47 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1664 posts
  • LocationUK
  • Registered Products:7
Posted 29 January 2014 - 08:49 AM
cheers
Lorenzo
Hi Lorenzo - is your updated routing schematic drawing the one in the first entry of this thread?  Or have you posted the updated drawing somewhere else?
Thanks.
#48 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 30 January 2014 - 10:42 AM
Thanks.
yes it's the one in the first post of the thread
#49 lwolford
lwolford
  • 21 posts
  • Registered Products:1
Posted 11 February 2014 - 08:13 AM
Hi everyone,
I'm a bit of a noob when it comes to the HD 500. Does the "post" position mean that it is modeling effects in the effects loop of the modeled amp or effects put on the signal between the microphone and mixer in a studio setup? To put it another way, is "post" post pre-amp or post amplifier? Thanks.
#50 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16066 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 11 February 2014 - 08:36 AM
The pre/post terminology applies directly to the POD HD Looper. If that's what you are talking about, it's much simpler than you think.
Pre means the looper records the incoming signal directly from the source(s), before it enters the DSP chain. This is used to record a dry signal and then tweak the tone hands-free (and/or change presets to hear the differences) while the looper plays back the recording for you.
Post means the looper records the fully processed signal, the same signal that is sent to the HD outputs. This is useful to record a backing track (e.g. A chord sequence) and then use it to play solo on top of using a different tone/preset.
If you are talking about the POD HD FX loop, that's a completely different thing and the pre/post terminology doesn't really apply. You can position the FX Loop anywhere you like in the signal chain, and using the 4-cable method you can fully control its position relative to the amp's preamp and power amp sections.
.... John Lennon
#51 lwolford
lwolford
  • 21 posts
Posted 11 February 2014 - 09:08 AM
Sorry, I must not have been clear. If I put an effect before the amplifier in the signal chain I understand that it is simulating plugging my guitar into an effect and then plugging the effect into an amplifier. If I move that effect to after the amp in the Pod's signal chain (either in path A or B or after the mixer), is that simulating putting an effect in the simulated amp's effects loop? I'm not asking about the effects loop on the Pod or a looper. Thanks again for responding.
#52 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 11 February 2014 - 12:44 PM
It simulates putting the FX after the amp-cab-mic.
In the real world, it is similar to passing your miced signal thru an effect in your mixing console.
#53 lwolford
lwolford
  • 21 posts
Posted 11 February 2014 - 01:03 PM
Thanks jandrio.
#54 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 11 February 2014 - 01:22 PM
u r wellcome.
Hope it helped u.
rgds/john
#55 darwan23
darwan23
  • 7 posts
Posted 07 April 2014 - 11:28 PM
Hi everyone,
according to many previous posts I redesigned the routing schematics of POD HD500 and tried to improve it just a little.
My goal was to include all possible kinds of FX blocks and show the difference between routing in A/B paths according to missing or using „pre“ FX blocks.
Any thoughts? Thanks for opinions…
Z.
https://drive.google.com/file/d/0B1xzHkOJtKipR09jWjNwa051MzA/edit?usp=sharing
  • 2
#56 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 08 April 2014 - 07:08 AM
Nice, Thanks for sharing such good info.
#57 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 08 April 2014 - 09:56 AM
Any chance you could post a PDF of this?  I had trouble making a nice copy to print out.
#58 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 09 April 2014 - 04:54 AM
here u r.
#59 darwan23
darwan23
  • 7 posts
Posted 09 April 2014 - 05:39 AM
Thanks for your export to PDF, I can add some "HD" vector render in PNG.
(if we are talking about "HD" product line here...)   :D
https://drive.google...dit?usp=sharing
P.S.: If anyone of you find something wrong in my drawing, I can redraw the old version...
  • 1
#60 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 09 April 2014 - 06:01 AM
Thanks!  I printed out this very nice document.
#61 GazzaBloom
GazzaBloom
    Iknowathingortwo
  • PipPip
  • 166 posts
Posted 09 April 2014 - 08:45 AM
OK I have to say I am struggling to get my head around this. My needs are simple:
1 x Guitar in - a few mono effects in 'pre' (drives, wah) - single amp - a few stereo effects in 'post' (reverb/delay) - output to Sudio/Direct via S/PDIF or output to DT25
What is the best input settings, mixer pans etc for this simple setup?
Gazza
#62 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 10 October 2014 - 01:53 AM
hi darwan23
I'm the author of the first schematics in this thread,
you did great with graphics, good job!
I'm sorry to be so late but I'm not following this forum much
I just have a pair of doubts/questions for you on the fx blocks you drew
1- which effects do you have in mind as "true stereo" as opposed to "Stereo THRU/Stereo Fx block"?
I think this distinction does not exist **
2- the "-6dB" involved in the mono summing into the effects is missing in your schematics, but I think it's very important to understand how the pod routing/gain-staging works
** what you call "Stereo THRU/Stereo Fx block" IS actually true stereo,
but a stereo effect that does not provide a mix knob such as an equalizer for example is true stereo too;
from your "true stereo" schematic it seems that these effects treat the left and right signals separately and generate two DIFFERENT STEREO signals and then mix them together:
no effect that I'm aware does such a thing in the pod
(only some evoved convolution reverb plugins actually do something like that).
Another two things I feel I need to clarify on your schematics for people that are trying to learn from this thread:
3- the two big schematics (with and without "pre split" FX) are exactly the same,
in fact I think darwan23 could get rid of the first one
the difference resides in which kind of effect someone chooses to put before the split, if it's stereo it will leave A and B paths separated
if it's mono or "mono fx / stereo thru" it will do what their schematics show
4- the continuous vs dotted lines to distinguish between mono and stereo signals could be confusing, in the sense that the dotted lines labelled L and R could also be representing two identical signals running in parallel which IS mono... it all depends on which effect you put where
also the two inputs could carry two sides of a stereo signal so the continuous lines could refer to a stereo and not mono signal
what I'm triying to say is that in darwan23's schematics there is no difference between what is drawn in continuous or in dotted fashion (it could be all continuous and work the same)
as always, I'm just hoping to help
bye
Lorenzo
  • 1
#63 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 10 October 2014 - 02:09 AM
and to Gazza
if you only need a simple setup you don't need to know all aspects of the routing (it doesn't hurt of course, but you don't NEED to), just:
- load an empty "new tone" patch
- load an amp (leaving the amp block where it is)
- IGNORE the A/B paths and the mixer
- load the pre-effects before the amp
- load the post-effects after the mixer
yes, it's THAT easy :)
  • 2
#64 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
Posted 10 October 2014 - 06:20 AM
Another problem I noticed, is when I have a dual signal and I'm just using Path A for my guitar, if I'm using my POD as an audio interface and the looper as post, the looper is half as quiet than the guitar signal, so it's not really usable when doing this.
I use Path B for my microphone.
I can just use Guitar Rig's looper when I do this though.
For a minute there, I lost myself.
#65 abidin_kadir
abidin_kadir
  • 1 posts
Posted 15 December 2014 - 11:11 PM
Excuse me can I know the setting-effect joe satriani - always with me, pod hd 500?
#66 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
  • Registered Products:8
Posted 16 December 2014 - 05:12 AM
Quote: "Excuse me can I know the setting-effect joe satriani - always with me, pod hd 500?"
Well you probably shouldn't pick random topics to post the request.
You should go here and take a look around: http://line6.com/customtone/
Welcome to the forums btw!
-Bill
Smell the glove.
#67 samsgs
samsgs
  • 73 posts
  • Registered Products:11
Posted 13 January 2015 - 04:38 PM
Wow!
New to dream rig and working on figuring out my dual DT/L3/JTV69S/POD 500X setup.
Haven't digested this yet but it is exactly the kind of help I have been seeking (I think).   Great info at worst.  Likely highly informative and can't thank enough!!!
Very cool!
#68 jegler
jegler
    Iknowathingortwo
  • PipPip
  • 134 posts
  • LocationThe Basement
Posted 12 March 2015 - 06:22 PM
The link to list of stereo/mono effects is broken. rrrrrrr.
www.redlightrecords.com
#69 amsdenj
amsdenj
    Gear Head
  • PipPipPip
  • 842 posts
Posted 12 March 2015 - 10:27 PM
Perhaps a simple best practice is to always set input 2 to "Same" unless you are using two separate instruments with input 1 going directly to path A and input 2 going directly to path B. Then the mono/stereo/amp effects work as expected in both paths.
  • 2
#70 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 13 March 2015 - 01:52 AM
Stereo/Mono FX List for POD HD
  • 3
#71 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 16 April 2015 - 12:13 AM
thanks, link edited
  • 1
#72 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 16 April 2015 - 02:43 AM
welcome :)
#73 wilson69978
wilson69978
    Iknowathingortwo
  • PipPip
  • 219 posts
  • LocationToronto
Posted 18 April 2015 - 11:52 AM
thank you perapera,  you've given us all lots to think about, and work on.
cheers.
#74 perapera
perapera
    Iknowathingortwo
  • PipPip
  • 126 posts
Posted 19 April 2015 - 03:18 AM
good to know, that was my intent!
#75 vpera
vpera
  • 27 posts
  • Registered Products:4
Posted 01 May 2015 - 07:50 AM
(Oh my... can't print and can't copy-paste on the forum, at least with IE, But back to the subject:)
Quote from "perapera":
"1 - which effects do you have in mind as "true stereo" as oppsed to "Stereo THRU/Stereo Fx block"? I think this distinction does not exist ** "
As a reply to this, the "Stereo/Mono FX list for POD HD" describes the effects:
"True Stereo - Left input goes to the Left output, Right goes to the Right output, effect is added to each channel separately"
I would call that "Dual Mono", or "Separated Stereo".
"Stereo Thru/Stereo Effect - Left input goes to the Left output, Right..., Left input is processed to create a stereo effect and mixed with the Left and Right outputs, Right..."
So Left -> Stereo, Right -> Stereo, outputs mixed.
Thus looks like the "jandrio"'s images "True Stereo FX Block" and "Stereo THRU/Stereo FX Block" should be reversed to get them roughly right.
#76 panaman
panaman
    Iknowathingortwo
  • PipPip
  • 131 posts
Posted 02 May 2015 - 04:31 AM
just when i thouhjt i had it figured out...
there really should be stereo effects only in a HD device. with a spread/width parameter and a mono switch. all the distortions and wahs dont take a lot of dsp anyways, and a stereo version would likely take  less than twice the dsp of the same mono effect.
think big. its a pod. you will love it.
#77 Glebber
Glebber
  • 20 posts
Posted 18 March 2016 - 12:33 PM
So my question is: Is it possible to use this method to hook up 2 separate guitar amps and use a different "amp block?" for each one? I realize it wouldn't be stereo but the amps are older Peavey Bandit 112 (silver stripe versions) . I like the POD so much through the effects loop of  the one I bought another thinking I can have the fullness of two amps while playing. Or is the answer to my question elsewhere? Thanks for the knowledge here, I'll have to really study this stuff.
#78 AFD-100
AFD-100
  • 11 posts
Posted 06 April 2016 - 11:43 PM
hi all
great thread - learnt a lot about the routing of the HD500x through here.
WRT running two 'real' amps on two separate paths on the HD500x - this is exactly what I've been doing.
one amp is a laney VC30 - I use the power amp section of this, going into the effects return loop input - effects on the HD then a pre model
second amp is a Marshall AFD-100 & 2x 4x12 - using the fx loop on this, just running simple effects - chorus, delay, reverb etc
(my guitar input has an A/B switch so I can select either HD path & corresponding amp)
All functions fine
I do however have one problem - hum
sounds like an earth loop - but I can only hear it on the Laney !
the Marshall is 100% silent
if I disconnect the marshall send & return feeds, the hum disappears totally
any suggestions ?!
#79 Gfer1484
Gfer1484
  • 52 posts
  • LocationChicago, IL
Posted 28 April 2016 - 05:34 AM
What effect would it have if you put the mixer at the front of the signal chain
USA Charvel/Jackson SoCal
Jackson SLXQ
Jackson DK2M
POD HD500X
ART HD-15
HD400 - Behringer Ultra-Compact 2-Ch Hum Destroyer
Marshall MHZ40C
#80 duncann
duncann
    Guru
  • PipPipPipPipPip
  • 2863 posts
  • LocationWI
Posted 28 April 2016 - 07:00 AM
If the mixer is absolutely the first thing in the chain, that means the second thing is the amp, which also means you can't have any effects before the amp. That's just the way it is when you try to do this. You can have effects before the mixer on either path while the amp remains after the mixer, so that would be the biggest benefit. You could set it up so that you could "pan" between the two paths, or two different effect setups, before it hits the amp, without actually using two amps.
Also tagged with one or more of these keywords: routing, signal routing, effect block, gain, input settings, hd500, hd500x, mono summing, unity gain
