floorboard, wah pedal does not go to zero
I am having an issue with my wah pedal on the floorboard. It does not reach the zero position, as in when I have the pedal at the bottom, its still open a bit. The volume works fine, goes to total zero.
I am using this as a midi controller and found this out, as the minimum position is about 22. Has anyone ever dealt with this before? Can the strip be re positioned or anything to make it go down to zero?
  • 3 years later...
I don't actually have one of these, but I think I know the problem: most Line 6 pedals are turned on and off by a little sensor under the toe side of the pedal, so if you want to turn it all the way off, don't just rock it all the way back, do a full forward toe tap.  That ought to disable it.
