Pod Xt Pro Driver Installation For Xp Doesn't Work
5 replies to this topic
#1 ole-x
ole-x
  • 3 posts
  • Registered Products:4
Posted 16 August 2013 - 08:00 AM
Hello,
I try to install my POD XT Pro on my Laptop. I'm running Windows XP on this machine. I downloaded the latest driver but after installation, I get the message
that it went wrong and the unit can't be started (Hardware Window / Code 10).
So Line 6 Edit nore Line 6 Gear Box do detect the hardware.
Any Ideas?
Thanks for help!!
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
  • Registered Products:6
Posted 16 August 2013 - 08:31 AM
Can Monkey see it?
Have you tried a new USB cable?
#3 ole-x
ole-x
  • 3 posts
Posted 16 August 2013 - 08:52 AM
Hey Triryche,
well I haven't testet a new cable, but the problem appears before connecting the unit already after installation of the driver.
for a moment, monkey and gearbox detected the unit, but when I tried to change the sound bank the unit ran down, startet again and so on.
I switched it off and on again, but it wasn't detected anymore.
I'll will try a new cable, but the driver installation problem is still there, I guess.
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 16 August 2013 - 08:58 AM
I would uninstall and reinstall the driver. Make sure your Pod xt is disconnected when you install the driver.
.... John Lennon
#5 ole-x
ole-x
  • 3 posts
Posted 16 August 2013 - 09:08 AM
Yes I have reinstalled it several times and the pod was disconected. The problem happened before connecting the POD. The Windows message says: The driver doesn't pass the "Windows Logo test" and then it says: There was a failure while installation and the unit can't be used. I try again with a new cabel tomorrow. Lets see what happens :)
Thanks for your help!!!!!
Best Olaf
#6 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 19 August 2013 - 05:19 AM
I'm sure you know already. But just in case, when you install the driver you should not have the PODxt Pro connected. Then, during the installation it will prompt you to connect it to complete the driver installation. Windows might give have a dialog box stated the driver is unsigned, click continue with installation.
