Dual Path, No Amps, Input Question.
input 2 dual path
2 replies to this topic
#1 StephenSLR
StephenSLR
    Iknowathingortwo
  • PipPip
  • 252 posts
  • LocationSydney, Australia
  • Registered Products:1
Posted 16 August 2013 - 02:28 PM
Can anyone explain what is happening here, I'm using this patch
http://line6.com/cus...ne/tone/208422/
It looks something like this:
                                      __ EQ__Amp A __
__EQ__Comp__EQ__ /                                 Mixer
                                    \ __ EQ__Amp B __
Both amps are switched off.
I have my guitar lead going into the 'Guitar in' and my output lead going out via the '1/4 out L mono'.
I've changed Input 1 to Guitar as has been recommended, it was originally Guitar + Variax.
Input 2 was originally 'Same' but I've read 'Variax' is recommended for a clean sound.
When I'm scrolling through the input 2 options, I find that 'Guitar + Variax' gives it a very full sound and 'Variax' for input 2 sounds rather flat. Why is this?
My guess is because there's no signal going to the lower 'Amp B' path, correct?
There is also a loud hiss when I select 'mic' even though I have no mic plugged in, what's going on there?
s
Listen to my band here:
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 16 August 2013 - 03:12 PM
What guitar are you using? Unless it is a Variax guitar connected to your Pod HD via the VDI connection, then your selection of Variax for any Input is effectively a null signal.
In that case, the reason for the difference between the 'Guitar+Variax' and 'Variax' inputs is that in the first case your guitar is being used in both inputs and in the latter case only Input 1 is receiving your guitar signal.In both cases I believe you have the signal going through both paths (amps). The difference is that in one case your guitar is doubled and in the other it is not.
.... John Lennon
#3 StephenSLR
StephenSLR
    Iknowathingortwo
  • PipPip
  • 252 posts
Posted 16 August 2013 - 06:16 PM
I'm using a Jackson Kelly and yes the reason they say to select Variax is so you don't get any interference from Input 2.
Ahh, okay,  I think I prefer the sound of my guitar being doubled, the tone is very full bodied.
s
Also tagged with one or more of these keywords: input 2, dual path
