redcloud Posted May 14, 2016 Share Posted May 14, 2016 Hi! I'm trying to make some changes to default patch 1C Lee Blue. In particular, I'd like to use the pedal 1 as wah. What I noticed is that when wah effect is acitvated and pedal value is at 100%, the tone is much more brighter than the original patch, it's changed radically! Is there a way to obtain the exactly same tone of the original patch when the wah is active and the pedal value is at 100%? The wah tone should change only when the pedal value is going down from 100% to 0%. Any suggestion? Thanks! Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted May 15, 2016 Share Posted May 15, 2016 In HD500 Edit software with the default patch engaged, click the Controllers Tab and remember the wah values you see for footswitch min/max (toe-heel) settings. Then call up your patch, click over the the Controllers tab, and set the footswitch to the same values you saw in the default patch. Quote Link to comment Share on other sites More sharing options...
redcloud Posted May 15, 2016 Author Share Posted May 15, 2016 Thanks, I've found the solution. In Controllers tab select first the wah model, select parameter->position min=0% max=100%, then parameter->mix min=100% max=0%. Quote Link to comment Share on other sites More sharing options...
