Laptop That Works With Hd500
laptop usb compatiibily
8 replies to this topic
#1 XCrossroadsX2000
XCrossroadsX2000
  • 59 posts
  • Registered Products:6
Posted 17 August 2013 - 12:38 PM
Can ayone reccomend a moderately priced laptop that works with HD500? I have a Dell Latatitude with Windows 7 and an Acer with Windows 7. Neither works with the HD500 and multiple discussions and supplying info to Line 6 could not resolve the issue. I think it may have to do with the multiple USB ports. Line 6 says not to use a USB hub and as these laptops have multiple USB inputs I am thinking an internal hub could be the issue.
So as I purchasing a new laptop, I'd like to avoid any issues.
Any reccomendations apprecciated.
#2 evilmikehoo
evilmikehoo
    Iknowathingortwo
  • PipPip
  • 166 posts
  • LocationBrandonville, PA USA
  • Registered Products:5
Posted 17 August 2013 - 12:44 PM
Hmmmm... I have an older HP with multiple USB ports and an older Dell Inspiron with 4 USB ports (I'm using it right now, as a matter of fact) and have't had any issues. Try using a different port. I've had issues in the past with other things and simply using a different port did the trick.
#3 XCrossroadsX2000
XCrossroadsX2000
  • 59 posts
Posted 17 August 2013 - 02:59 PM
Thnax tried all the ports, reinsatalled monkey multiple times. Multiple calls with support. Monkey or HD interface does not recognize HD500 or UX2 hardware, though Windows sees it as a device.
Both work fine on my 64 bit Vista Workstation and XP workstation but I want something portable.
Really wish Line 6 would develop a tablet interface.
#4 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1243 posts
  • LocationUK
Posted 24 August 2013 - 08:50 AM
My Acer S200E (Windows 8 inc touchscreen) works fine - I have been using it as a VST host with the HD500 as the Audio Interface.
In fact I have more problems with the generic USB MIDI than the HD500
#5 dprasen
dprasen
  • 6 posts
  • Registered Products:1
Posted 28 August 2013 - 09:59 PM
I tried my UX2 with Toshiba Satellite Intel I3 with 2 GB Ram, it had latency issues, kindly help!!
Whats the ideal configuration for a laptop to work smoothly with UX2
#6 scottyo78
scottyo78
    Iknowathingortwo
  • PipPip
  • 240 posts
  • LocationSeattle, WA
  • Registered Products:2
Posted 30 August 2013 - 04:38 PM
dpraen... You my fellow Line 6 commrade are probably in the wrong forum for UX2 info.
This forum may serve you better?
#7 wildbillmojo
wildbillmojo
  • 17 posts
Posted 31 August 2013 - 05:27 AM
Anyone tried an HD500 with a Microsoft Surface Pro?
#8 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5384 posts
Posted 31 August 2013 - 08:43 AM
I have used HD PODs with Lenovo Thinkpad 410 (a little pricey) & several different Lenovo Ideapads ($300 and up)...Also a couple of different HP laptops...good luck.
#9 Thidsa
Thidsa
  • 4 posts
Posted 31 August 2013 - 03:43 PM
Tried a Latitude E6410 today just to see. No problem at all.
Be sure to remove and reinstall the driver, not monkey.
Its most likely a driver problem(what sometimes happen if you had plugged the pod in before installing the drivers from line6). Find the pod in device manager and change driver to the one in line6 folder in program files.
Bjoern
Also tagged with one or more of these keywords: laptop, usb, compatiibily
