meduz Posted May 22, 2016 Share Posted May 22, 2016 hello, thanks in advance for reading and sorry for my english, i'm french... i bought a pod hd500 second hand who works perfectly when i got it. 3 days ago when i start the pod I could see many troubles... the button of the left directional pavement does work anymore... in the setlist menu the arrow to select the setlist moved alone... impossible to acces to tuner... the sound drops out when a guitar is connect... all changes i made in the general menu does not saved when i restart the pod... after several minutes it finally block on Looper fonction. all updates are ok. I update one more time the last firmware, rollback old firmware and update last formware... no change... I opened support ticket... thanks in advance if you could help me... jerome Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted May 22, 2016 Share Posted May 22, 2016 When mine played up I found inside that the ribbon (computer) cable had come loose. I pushed the blue connectors back together and it worked fine. Only open it up if it's out of warranty though! Quote Link to comment Share on other sites More sharing options...
meduz Posted May 23, 2016 Author Share Posted May 23, 2016 thanks ! i will take a look Inside. (warranty is down) Quote Link to comment Share on other sites More sharing options...
meduz Posted June 23, 2016 Author Share Posted June 23, 2016 I finally solved my problems.I unsettled everything and coated the printed circuit as well as the buttons of navigation with a cleaner contact...go in test mode to verify everything / expression pedal calibration and put back the lastest firmware another time. waiting few minutes and all works good !!! i think it was a problem with the nav buttons (left) wich put the pod in RAZ mode each time of ignition... my warranty was down so DO NOT the same thing if your warranty is OK. Quote Link to comment Share on other sites More sharing options...
