bptrav Posted May 23, 2016 Share Posted May 23, 2016 Does anyone know of a way of copying or moving patches on the hd500 itself without software? I find myself mostly using a few patches that are far apart from each other in my current set list and would like to put them closer together. I have a computer with the software to do it. I'm just wondering if it's possible on the device itself. Thanks Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 24, 2016 Share Posted May 24, 2016 Does anyone know of a way of copying or moving patches on the hd500 itself without software? I find myself mostly using a few patches that are far apart from each other in my current set list and would like to put them closer together. I have a computer with the software to do it. I'm just wondering if it's possible on the device itself. Thanks When you hit "save" once on the POD, it prompts you to select the location where the patch will be stored. With the first 2 control knobs below the display, you can select a slot in a different set list, or another slot within the same set list. Hit "save" a second time and it's done. Just know that you're copying from one slot to another, and over-writing the patch that had been stored in the new destination...unless it was an empty slot. 1 Quote Link to comment Share on other sites More sharing options...
bptrav Posted May 24, 2016 Author Share Posted May 24, 2016 Thanks for the replies. I actually knew you could choose where to save a patch to but hadn't thought of saving a patch that I had already saved somewhere else. That will work fine since I mostly using a handful of patches right now and half my setlist was empty anyway. :) Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted May 24, 2016 Share Posted May 24, 2016 Google search for the Pod hd500x Advanced Pilots guide, download and go to section 4.1 there's everything you need to know about editing and managing setlists without the editing software. Quote Link to comment Share on other sites More sharing options...
