Sustained A Chord
6 replies to this topic
#1 duranduran
duranduran
  • 11 posts
  • Registered Products:4
Posted 18 August 2013 - 09:26 AM
Hi guys i'm trying to find a way of sustained a chord (20 seconds) and play over it (hd500)
#2 mralmostpopular
mralmostpopular
  • 33 posts
  • Registered Products:1
Posted 18 August 2013 - 09:32 AM
You could start the looper recording after the initial attack, and cut it off before the sound starts to die off. It might take a little practice, but that should allow the chord to sustain for as long as you want.
#3 pfsmith0
pfsmith0
    Gear Head
  • PipPipPip
  • 558 posts
Posted 19 August 2013 - 09:40 AM
Put a volume control in front of a delay. Rock the volume back while you strum and then rock it foward. You want to feed the delay with only the sustained part of the chord, not the attack. Keep doing this at a rate that keeps the decay from the delay minimal. Usually you can set it up so you only need to strum every few seconds. It'll sound like one hugely long chord as long as you keep your strum volume consistent.
#4 drschultz
drschultz
    Iknowathingortwo
  • PipPip
  • 117 posts
  • Registered Products:3
Posted 19 August 2013 - 02:55 PM
Hello, I made a patch to copy David Gilmour's Sound on Sound.  Here is the link on customtone.
http://line6.com/cus...one/tone/222341
Please read the description as it tells you how to operate the foot pedal.  You may have to extend the delay but it should work.
Good luck,
-Dan
#5 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 274 posts
  • Registered Products:5
Posted 22 August 2013 - 06:54 AM
I played around with this and the perfect solution for me was to buy an EHX Superego and put it in the FX loop of the HD500.  Not the cheapest solution but the pedal is capable of some really cool sounds that, for me, justified adding it.
#6 jefflynyrd
jefflynyrd
  • 80 posts
Posted 22 August 2013 - 11:08 AM
Drschultz! That worked perfect! Awesome! And Timing is a factor. Great work! :D
#7 drschultz
drschultz
    Iknowathingortwo
  • PipPip
  • 117 posts
Posted 23 August 2013 - 03:38 AM
I am glad it worked for you.  Here is my take on Shine on you crazy diamon, using that patch.
http://www.reverbnat...0-crazy-diamond
