WilliamWills Posted May 28, 2016 Share Posted May 28, 2016 I've just gotten my FBV 3 and the expression pedal to go with it through the door today, I have updated it and got it all running and changing my tones as they should. The current way to interacts now is that my wah pedal on the FBV 3 only does wah when clicked (as it should) but doesn't do anything when not clicked and moved (I want that to be my volume adjuster) and my expression is my volume at the moment. So I want my expression pedal to have a dive bomb effect for the song lonely boy and then my FBV pedal to be for wah/volume. Please can someone point me in the right way and let me know if I need to expand or clarify what I have put, I have tried using the Line 6 Control app but I can't get the hang of it. Thanks -Will Quote Link to comment Share on other sites More sharing options...
HoopUte Posted May 30, 2016 Share Posted May 30, 2016 I'm having a very similar problem that just cropped up on a 6 year old MKII Shortboard. I'm not sure they're the same issue, though. In your case, have you checked the pedal calibration? If you've never done that, power the amp off and hold down the "D" switch when you power back up. It will walk you through a process to set the pedal volume from 0 to 127. Push all the way down with your toe, press D, pull it all the way back with your heel, press D again, it will have you push the Wah switch, press D, and then it will give you a calibration check. My problem, which just cropped up, appears to be that the expression part pedal is no longer being "detected" by the unit. When I power up I can only get volume in the Wah position, but I have no wah control. Also, I can't walk through the calibration process. It gives me the tow down message, I do and press D, and nothing happens. I'm kind of thinking I'm screwed on this one and have to by another shortboard, but maybe not. Any help on this would be appreciated. Quote Link to comment Share on other sites More sharing options...
