HD500 guitar in doesn't work
nhmusicman
Have been using my pod hd500 as an interface for vocal recording to my Mac and with a festival gig on its way, thought I'd run the guitar through it.
To my surprise the "guitar in" no longer seems to be receiving a signal... No sound and even the tuner is not receiving any sound.
I've plugged the guitar into the "cd in"and that works fine but I can't use any effects using that!
Any ideas?
Thanks in advance,
Nick
Yes, like phil said, check the input setting. Make sure you've got guitar input correct. Make sure if a pedal is assigned it's set correctly. Check the volume levels of the mixer. Try starting out with a blank patch with the correct input settings.
Are you in FS 5-8 mode the switches effects on and off rather than Patch select mode "ABCD" - it is another global setting?
You're right! That's exactly the problem I was having - thanks for clearing that up! Not used the POD for guitar in years so should re-read the manual, clearly!
Thanks all.
Nick
