jesuscares Posted June 9, 2016 Share Posted June 9, 2016 I have a few tube amp heads including a line 6.Some of them come with line out of recording & some like the Egnator 15 w only has a speaker out & effects send/return.What is the best way to record this sound via sn interface without using a cabinet or mining the cab? Do I need to plug the speaker out into a DI box? Will the behringer DI ultra do the job? http://www.sweetwater.com/store/detail/DI100/?adpos=1t1&creative=110418914761&device=c&matchtype=b&network=g&gclid=CPqV2IOmms0CFdgWgQodiOkC7w I have a Spider valve amp that is too loud.can I just disconnect the speakers & feed it through the DI & record safely? Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 9, 2016 Share Posted June 9, 2016 Amps like the Line 6 that have a Line Out/Headphone jack that automatically disengages the speakers can be used as a DI direct to your audio interface input(s) because the amp output section is effectively disengaged when you do this. You do not want to run any amp not wired this way without a connected output. A DI box is not what you want if you want to run the speaker output of an amp to your interface input - you need a power attenuator/load box like this one: http://www.sweetwater.com/store/detail/RockCrusher Quote Link to comment Share on other sites More sharing options...
jesuscares Posted June 13, 2016 Author Share Posted June 13, 2016 Amps like the Line 6 that have a Line Out/Headphone jack that automatically disengages the speakers can be used as a DI direct to your audio interface input(s) because the amp output section is effectively disengaged when you do this. You do not want to run any amp not wired this way without a connected output. A DI box is not what you want if you want to run the speaker output of an amp to your interface input - you need a power attenuator/load box like this one: http://www.sweetwater.com/store/detail/RockCrusher Thanks for the reply.Line 6 does a great job with direct line outputs for recording.I have the Spider valve & thats exactly what it does,although there is still no way to bypass the sound coming out of the speakers which is way too loud. The Behringer DI does claim to eliminate the speaker though.Not sure how far authentic though.Here is what the link says on the Behringer DI posted above : Allows direct connection to speaker outputs with up to 3,000W Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 13, 2016 Share Posted June 13, 2016 There's nothing in the Behringer description that says it provided a LOAD to the amp, only that it attenuates the signal. Quote Link to comment Share on other sites More sharing options...
