musicimpossible Posted June 13, 2016 Share Posted June 13, 2016 Have the opportunity to purchase a used JTV60 with a battery but no charger or VDI cable. Prior to purchasing a battery charger, if I purchase a VDI cable and connect the JTV to my Helix, would that power the guitar? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 13, 2016 Share Posted June 13, 2016 Yes. Effects boards (including Helix) with VDI jack will power JTV,as part of its function through the VDI cable. Be sure to use the actual VDI cable with the XLR shells on both ends. http://www.fullcompass.com/prod/115205-Line-6-Variax-Digital-Cable There is also the TRS cable, for when you are running with the battery,... http://store.line6.com/accessories/cables/variax-trs-cable-15.html ... TRS is used on many kinds of guitars like ours, with active electronics. Quote Link to comment Share on other sites More sharing options...
theKennyG Posted June 14, 2016 Share Posted June 14, 2016 One warning though. You'll need a charged battery to connect to the Variax Workbench. At the moment, Helix doesn't act as an interface for workbench. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 14, 2016 Share Posted June 14, 2016 Correct,... there's a interface widget and cable for doing Workbench HD and updates through Monkey. That stuff will be in the manuals. Quote Link to comment Share on other sites More sharing options...
DannyMcO Posted June 18, 2016 Share Posted June 18, 2016 On the Neutrik connections for Cat 5 cables, how does one release the locking tab on the RJ45? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 18, 2016 Share Posted June 18, 2016 The RJ-45 locking tab is not engaged by the neutric connector. It locks with a rectangular hole in the neutric sleeve. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted June 18, 2016 Share Posted June 18, 2016 You should remove the tab. Quote Link to comment Share on other sites More sharing options...
