Podxt Variax Workbench "no Device Detected"
6 replies to this topic
#1 stevewburke
stevewburke
  • 7 posts
  • Registered Products:3
Posted 20 August 2013 - 01:11 PM
I can't start Variax Workbench. Monkey works and can see my PODxt by USB connection and Workbench sees the device too as "Line 6 PODxt Live" but right below it it says "No device detected" even though it clearly sees the device.
I updated the firmware and flash memory through Monkey and also tried reinstalling the drivers, but no luck. I also tried a different USB cable and also tried plugging different USB ports.
I have Windows 7 64x and assumed it was a 64 bit issue, but I found other people on the forums with 64x Windows 7 who had no trouble getting it working.
#2 BigChas52
BigChas52
    Guru
  • Line 6 Expert
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 20 August 2013 - 01:17 PM
Make sure you have something plugged into the Variax 1/4" jack.  The guitar will not power up without being plugged in.
#3 stevewburke
stevewburke
  • 7 posts
Posted 20 August 2013 - 07:03 PM
Variax 1/4" jack on a PODxt Live pedal board? The 1/4" jack was plugged in with a regular guitar, but the only Variax connection is the ethernet.
Also, I've used this thing in the past through USB without needing a guitar (Variax or otherwise) connected to it.
#4 stevewburke
stevewburke
  • 7 posts
Posted 22 August 2013 - 01:09 PM
Anyone?
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17713 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 22 August 2013 - 01:14 PM
which variax? if you updated a JTV to 2.0 you need to use variax workbench HD and a variax workbench interface.
if it's one of the earlier variaxes you might make sure that java is installed...
#6 stevewburke
stevewburke
  • 7 posts
Posted 22 August 2013 - 04:56 PM
I'm just trying to get the PODtx pedal board to work in Workbench like it used to - without the Variax guitar attached. I don't get why it would recognize it then say it can't be recognized.
The Line 6 drivers installed Java.
#7 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17713 posts
Posted 22 August 2013 - 05:19 PM
workbench cannot be opened without a variax attached.... perhaps i still don't follow you...
