Recording Pod Hd 500 Pc
Raphael26
"Audicity" is a completely free open source multi-track recording program.
Look it up (it's everywhere on the net) and read about it and use it... it should do all you need as you start out.
Personally I use "Studio One Pro" which is about $400.
I would recommend against using ASIO4ALL, the default device interface driver with Audacity. While it works for some, it is not a true ASIO compliant application and has been known to cause issues when used with Line 6 devices. If using Audacity, make sure to change the device driver to the Line 6 ASIO driver.
I recommend you also look into Reaper as the recording program. It has a free fully-functional trial period and then is approximately $60 for license.
