Mixing Magnetics With Models
19 replies to this topic
#1 dtray187
dtray187
  • 34 posts
  • Registered Products:1
Posted 20 August 2013 - 03:45 PM
Has anyone tried this yet? I just noticed it was in the update
#2 totoleheron
totoleheron
  • 13 posts
Posted 21 August 2013 - 01:26 PM
No, how do you do that?
#3 TxHCBP
TxHCBP
  • 34 posts
  • LocationCentral Texas
  • Registered Products:7
Posted 19 September 2013 - 01:40 PM
Looks to me like the bottom right hand corner of the WB control panel. You can see the word "Model"; to the left of that is the control slider for the Mag/Model blend.
#4 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 19 September 2013 - 04:06 PM
You can blend the Mags and the models - just keep in mind that the mags can't be pitch shifted.
#5 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1833 posts
  • LocationGreece
  • Registered Products:12
Posted 20 September 2013 - 12:48 PM
I did it.I mix about 29% the mag with the tele bridge and came out awesome. My guitar 69s
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
#6 stevedodd
stevedodd
  • 14 posts
Posted 06 December 2013 - 09:18 AM
So in theory something like a Fernandes Sustainer could be fitted as well and mixed? Cool.
#7 McLenison
McLenison
  • 99 posts
  • Registered Products:2
Posted 06 December 2013 - 12:13 PM
That is cool!  So if you blend in a little, I assume you wont perceive much, if any, latency.
#8 guitarno
guitarno
    Iknowathingortwo
  • PipPip
  • 223 posts
Posted 06 December 2013 - 01:08 PM
   That's true. You'll hear the initial attack of the mags, and it will mask any latency of the modeled sound, but as Post #4 stated, you can't do this and use ANY altered tunings, or it will sound terrible. You'd have to be real careful about which models you do this on & what patches or tunings you use them for. I do like the sound of the mags mixed in for some sounds. If you don't use alternate tunings, or you don't on specific models, it's not really an issue.
   You can also do this without adding the mags to a specific model in WB, on a patch basis by using input 1 set to "Variax" and input 2 set to "Variax Mags", and avoid having the mags mixed into a model by default. If you wanted to mix the proportion of model to mags, you'd really have to have them separated on a dual path patch.
#9 McLenison
McLenison
  • 99 posts
Posted 06 December 2013 - 01:31 PM
I wonder how the mags would sound blended with a model that had alt tuning as a 12 string counterpart, i.e., octaves for E A D G and detuned B and E strings.  That may be worth playing around with.
#10 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 06 December 2013 - 01:44 PM
You can mix with alternate tunings that are in harmony like a 5th.  Sounds cool.
#11 radatats
radatats
    Power User
  • PipPipPipPip
  • 2326 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 25 April 2014 - 09:17 AM
When blending mags with models, does anybody know which mags are actually blended?
Does it blend the pickups from the model or does it blend the pickups associated with the actual position of the selector switch?
For instance, if a model in position 5 (neck pickup) has bridge and middle selected, does the JTV blend the neck or the bridge and middle?
#12 smrybacki
smrybacki
    Gear Head
  • PipPipPip
  • 669 posts
  • LocationCarlisle, PA
Posted 25 April 2014 - 09:26 AM
Really?  I missed that in the memo.  Coolio.
However you play music using whatever gear you may choose that day-- the JOY of making it is the heart of it.
#13 jefflynyrd
jefflynyrd
  • 80 posts
Posted 25 April 2014 - 11:09 AM
You would be blending the pactual pick ups of the (your) JTV.
#14 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 25 April 2014 - 12:23 PM
My guess is that it blends the pickups based on the selector switch position so you might have to move your  models around to get the blending you like.
  • 1
#15 radatats
radatats
    Power User
  • PipPipPipPip
  • 2326 posts
Posted 25 April 2014 - 12:45 PM
Unfortunately there is more than enough going on in there to allow for either possibility but there is absolutely no official guidance on the truth...  time for an Expert or Specialist to step in...
#16 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 25 April 2014 - 12:49 PM
Reason I say that is that I believe that the Mags are directly switched by the 5 way switch on my 69S.
  • 1
#17 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 25 April 2014 - 01:01 PM
c abstract from workbench hd manual  (page 10) on foll:
http://line6.com/sup...ge-7#entry47129
The correct answer is that whatever pickups u have selected via the selector switch, those ones will b blended.
  • 1
#18 radatats
radatats
    Power User
  • PipPipPipPip
  • 2326 posts
Posted 25 April 2014 - 02:58 PM
Thanks!  I totally missed that... I just realligned my models in the Custom 1 bank to match up with the mags.  Very interesting, I get a much clearer tone on chords, higher notes are more defined with the mags blended in...  Kind of wish I hadn't started playing with it cause now there are a million new things to fiddle with...  :D
  • 1
#19 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1833 posts
  • LocationGreece
Posted 25 April 2014 - 03:17 PM
As a matter of fact, I am curious how the 59 sounds that has only 2 pickups and a 3 way selector on strat's position 4 and 2
#20 anonyrat
anonyrat
  • 93 posts
  • Registered Products:4
Posted 25 April 2014 - 09:52 PM
Well I would guess that the 59 in pos 4 & 2 would behave like a 59 in 5 & 1 as the selector is in bridge / neck and 4 & 2 is only electronically achieved.
  • 1
