Weird exp pedal problem
Shadowrunner
OK, so I bought an EX-1 to go with my HD500, but I am having, as stated in the title, a weird problem with it. In Edit, which I use for 99% of my manipulation of the HD500, I can see the needle on the effect moving as I move the pedal, but on the LCD on the HD500, the it doesn't appear to be doing anything. I can adjust the position manually with the knob, and the sound changes as expected, but for some reason the external pedal doesn't work. The built-in one works fine.
you have to send your changes to the pod before moving pedal and knobs, i send and save each time. else changes in edit will be undone, theyre only temporary. its more like a bug than a feature. pod and edit are not in sync.
