Dt25 Boost Through L6 Link?
l6 link boost dt25
7 replies to this topic
#1 sasajungic
sasajungic
  • 7 posts
  • Registered Products:7
Posted 22 August 2013 - 02:19 AM
Is there a way to use a boost through L6 link (but not through the pod fx loop)?
I have Pod HD500 and DT25 working with L6 link but I'm also using HD500 with standard amps half the time.
I have also Xotic EP booster which I really like for the solo boost - after HD500 before the amp and it works great.
So if I use L6 link to DT25 I lose the ability to use it before the amplifier as usual and that is where I find it sounds the best.
Maybe there is some kind of connector or interface that I could buy or make that would allow me to do that and use EP booster in both configurations?
Did someone find a way around this?
Thank you!
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17814 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 22 August 2013 - 02:42 AM
just put the effects loop at the end of the chain, and put your pedal in the loop, is there some reason you don't want to do that?
#3 sasajungic
sasajungic
  • 7 posts
Posted 22 August 2013 - 03:07 AM
There are four:
1. I have something already in the fx loop (POG2).
2. I still wan't to use booster last in chain if in front of a regular amp  where it doesn't cause any clipping of the digital path but rather a real volume boost and nice tone.
3. Actually wouldn't that differ when on L6 link with DT25 if boost is last in the pod chain and not first hitting the preamp and then poweramp? I don't know...
4. In case of DT25 failure, I could use any standard amp available at the venue.
Thanks!
#4 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5353 posts
  • Registered Products:6
Posted 22 August 2013 - 09:42 AM
It takes a couple of cables, but you could just put it in the DT25's FX loop....The send is the analog end of the link coming form the pod (end of the chain)...return is the power amp in....If the DT25 failed and you used another amp, then that might be HD500 1/4 out-> booster-> spare amp power amp in...I often run a DM3 in my DT loops...
#5 sasajungic
sasajungic
  • 7 posts
Posted 23 August 2013 - 06:32 AM
So what is the tech behind L6 link through XLR jack?
That is 100% digital right? Just data?
No way to make simple interface then.
#6 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 23 August 2013 - 06:50 AM
It is 100% digital.  Digital audio goes one-way, control information is two-way.  I don't think there would be any way to make a simple interface.  As spaceatl suggested previously, your best bet might be to use the DT25's FX loop.
#7 sasajungic
sasajungic
  • 7 posts
Posted 26 August 2013 - 05:49 AM
Thanks guys.
At least this clarifies things for me.
Best two options as I see it are....
a/ I'll have two identical set lists...one for DT25 with "virtual" EP pre and one for regular amp when I'll use the real one on the board if the DT goes down or I wan't to use a regular amp.
b/ to make secondary EXP latch pedal for boost control per patch. I should be able to do this even though it doesn't sound the same but I don't need a set list duplicated.
Shame I can't use it the way I use it with standard amp to slam the input....FX loop is not an option as I explained earlier.
Cheers
#8 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5353 posts
Posted 26 August 2013 - 08:57 AM
I know it is a little pricey, but have you thought about something like a loop bone? Might be handy box to have...
http://www.tonebone....tb-loopbone.htm
Also tagged with one or more of these keywords: l6 link, boost, dt25
