Modulated Reverb
jamesnlcc1
You probably already know this but as a workaround, you could put a reverb and your choice of modulation after the reverb, in path A after the amp with the reverb mix at 100% and the modulation mix to your taste. Then, using the mixer with A & B panned to center (0), use the A & B sliders to adjust your mix between the "dry" amp on path B (the path with no FX) and the reverb/modulation on path A.
