assigning looper pedal
jazzjam
I myself have not yet figured out how to add an additional path immediately beneath the one I am on, but what you can do is start out with the '4 tone switcher' template, and have each tone run into the next by changing the inputs and outputs.  That will get you more stomps to add into your chain, though I suspect you will run out of dsp before too long.
I have not figured out how to modify a current patch, and add an extra stereo path like what you get in the 4 tone switcher.  There is probably a way, but I haven't figured that out yet.  If anyone knows, please share.  In any case, starting they way I mentioned will get you the extra stomps you are after.
Well.. I just figured that out actually.  Add a volume/pan gain pedal to the end of your chain, and then move/drag it down and a new stereo path will appear immediately below the current.  you can then grab the split and move that to create a new stereo path altogether if desired.
