Hd 500 Solution
1 reply to this topic
#1 Sync100
Sync100
  • 3 posts
Posted 23 August 2013 - 08:20 AM
A while ago I was having an awful time with noise using my HD500 recording the s/pdif output.
I got lots of advices and links and it did help greatly.
Then I picked up a used Peavy Valve King Royal 8. So noisy and it sounded lollipope thru the craped out 8'.. I installed a speaker ext jack and use my old not working Spider II as a speaker cab. Big improvement but the Amp was still noisy.
A few weeks ago I picked up a used Isolating transformer for silly money from an Auction and l got to tell you how quiet things are now.
This thing really cleans the line and filters it as well. Basically the transformer unlike a stepdown or stepup maintains the same voltage and like all transformers isolates the input into the primary coil by inductance pickup in the secondary coil. This one has filtering thru the common earth.
Not to be confused with a Power Conditioner which are over priced power strips imo that offer filtering and surge protection but alas noise on the AC still gets in unless it contains an isolating transformer. Expensive too.
The Amp is now quiet the guitars are now quiet, even when hands are off the strings and the POD HD is  bearable using high gain amp and Distortion models.
Do yourself a favour and get yourself one for the Studio and while heavy, worth it on the road too!
#2 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1198 posts
  • Registered Products:2
Posted 24 August 2013 - 01:34 AM
Wow Déjà vu,
I think I wrote an almost identical post a while back.
You sure your not  taking the mickey out of me? LOLOL
The Royal 8 are notoriously noisy and the transformer certainly quietens it and guitars which I have also shielded.
Mine is in need of a new power amp valve which I have on their way.
I have heard replacing the output transformer also improves the tone but I kinda like it without the HD in front. Sort of voiced like a Vox I reckon.
