vettahead Posted July 27, 2016 Share Posted July 27, 2016 Well, judging by my name can you guess what i came from? :D So far this thing sounds fuggin amazing (although daunting even though i came from the vetta) I just wanted to ask one question. should i enable or disable the global eq thing? sounds i bit toppy in my senheisers you see! Oh and can you recommend some of the better tones to get used to the system from the downloads bit (snapshots esp as thats totally alien!)? i find it easer to deconstruct stuff to understand how they work. Thanks all Vetta Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 27, 2016 Share Posted July 27, 2016 The global EQ is entirely optional. I would say experiment with it. If you like it, keep it on. If not, turn it off. At worst you will gain some insight into how it works. As for tones, I suggest you browse through the TEMPLATES setlist and start reverse-engineering those examples of preset types. 1 Quote Link to comment Share on other sites More sharing options...
RRMark Posted July 27, 2016 Share Posted July 27, 2016 Hi, I sometimes use my Vetta2 return for a stereo poweramp/cab, pretty decent. As a starting point folks seem to like eq with a low cut 60Hz and hi cut of 6kHz. Most would recommend these cuts applied in the cab block or an eq block and reserve global eq to adjust all presets for different monitoring situations. 1 Quote Link to comment Share on other sites More sharing options...
ncockerill Posted July 27, 2016 Share Posted July 27, 2016 Hi, I sometimes use my Vetta2 return for a stereo poweramp/cab, pretty decent. As a starting point folks seem to like eq with a low cut 60Hz and hi cut of 6kHz. Most would recommend these cuts applied in the cab block or an eq block and reserve global eq to adjust all presets for different monitoring situations. I second this recommendation. I have found that using a low cut/high cut on the cab block(s) works very well. How your patches are constructed and your choice of guitar will determine the amount of low cut/high cut that's necessary. I use the global EQ as a means to tweak for live settings, based on the dynamics of the room. 1 Quote Link to comment Share on other sites More sharing options...
