How Do I Monitor Sound Through Workbench?
8 replies to this topic
#1 CBTL
CBTL
    Iknowathingortwo
  • PipPip
  • 250 posts
  • Registered Products:2
Posted 24 August 2013 - 08:54 AM
So here it is, when I conect to workbench 2 through the hub to mod some guitars there is obviously no sound and have to swap back and fourth between my hd500. It's so frustrating, there must be a way of monitoring so I can tweak on the go?
#2 ReverendLove
ReverendLove
    Iknowathingortwo
  • PipPip
  • 124 posts
  • LocationCologne, Germany
  • Registered Products:4
Posted 24 August 2013 - 08:58 AM
Why don't you use the usual 1/4" guitar in on your pod like with every other guitar?
#3 CBTL
CBTL
    Iknowathingortwo
  • PipPip
  • 250 posts
Posted 24 August 2013 - 09:00 AM
It goes haywire with both the vdi and 1/4. It messes WB right up!
#4 ReverendLove
ReverendLove
    Iknowathingortwo
  • PipPip
  • 124 posts
Posted 24 August 2013 - 09:09 AM
Strange. It works here.
Probably you should try to set the input "guitar" only. Or there is something like an USB conflict. Try to pull the USB cable from your POD.
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17810 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 24 August 2013 - 09:18 AM
works for me with both interface and 1/4"
it can do strange things from time to time if i'm changing things too quickly... but works easy enough for the most part.
#6 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 24 August 2013 - 09:26 AM
If it acts up this way, you probably have a grounding problem between your computer and your amp / pod.  I have seen this cause the USB connection to act up.
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15909 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 24 August 2013 - 09:30 AM
Do not connect your HD500 to your computer via usb (e.g. do not run both HD500 Edit and Workbench at the same time). Connect your Variax to the computer running Workbench using the Workbench hardware interface. Connect the 1/4" output of your Variax to the HD500 Guitar Input (or use VDI/Varaix Input) and monitor the sound using the HD500 audio outputs. This setup should work.
.... John Lennon
#8 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17810 posts
Posted 24 August 2013 - 09:50 AM
you cant connect to the 500 via VDI and the interface at the same time... methinks you got confused :)
#9 bm1961
bm1961
  • 8 posts
Posted 26 August 2013 - 04:35 PM
I had the same problem, but figured it out...
http://line6.com/sup...iax/#entry12767
Hope this helps.
Brook
