357mag Posted August 14, 2016 Share Posted August 14, 2016 Just wanted to make sure I am clear on something. If I bought the Metal Pack Model Pack for the HD Pro X I would be getting the Marshall JCM-800 Model 2204 plus the Peavey 5150. Correct? Another question is are these model packs only accessible to user through the HD Pro Edit software, or do they actually go in the HD Pro X unit itself? And what is the difference between the Marshall JCM-800 that is already in the HD series units, and the 2204 which is available when you buy the model pack? Quote Link to comment Share on other sites More sharing options...
Metalal5150 Posted August 14, 2016 Share Posted August 14, 2016 Just wanted to make sure I am clear on something. If I bought the Metal Pack Model Pack for the HD Pro X I would be getting the Marshall JCM-800 Model 2204 plus the Peavey 5150. Correct? Another question is are these model packs only accessible to user through the HD Pro Edit software, or do they actually go in the HD Pro X unit itself? And what is the difference between the Marshall JCM-800 that is already in the HD series units, and the 2204 which is available when you buy the model pack? Hi. Firstly there is no" Metal Pack Model Pack "available out there. If you buy "HD Metal Pack " then you will be getting a new models that will install to your HD unit . Amps as follow : Peavey® 5150® (Block logo) Bogner® Shiva Remastered Marshall® JCM800 (Model 2204) Line 6 Insane Line 6 Big Bottom Line 6 Variac'ed Plexi Line 6 Purge Line 6 Aggro Line 6 Smash Line 6 Octone And yes you will be able to edit /tweak /do whatever with those amps in the same manner as you are editing the existing amps in the Edit mode on your PC/Laptop. And the difference between the stock JCM 800 to the Remastered one that comes with the HD Metal Pack is that they actually Remastered the JCM 800 sound and based this on model 2204 . Marshall made few models of JCM 800 like 2203,2204,2205,2210,4210 and 2204 was actually the one that sounded the best so they decided to go for this model as an upgrade. Hope this helps :) RESPECT! Quote Link to comment Share on other sites More sharing options...
357mag Posted August 14, 2016 Author Share Posted August 14, 2016 I meant the model pack you are referring to. Maybe I got the name wrong. Good news for me then. I was hoping I could install these additional amps right into the unit. Also good news in hearing that the 2204 is better sounding. Thanks. Quote Link to comment Share on other sites More sharing options...
