Toneport Ux2, Midi & Cubase 7
4 replies to this topic
#1 gruser
gruser
  • 7 posts
  • Registered Products:1
Posted 26 August 2013 - 02:14 AM
I am using the above setup to drive some East West VSTs. This works fine for the most part.
I have one very annoying issue. When the first note is played there is a slight glitch noise/delay while the midi appears to "kick in". Every note after this is fine with no latency until there is a break in playing. Then the same situation repeats for the next "first note".  The issue isnt limited to Cubase 7 and occured in Cubase 5 too.
In what maybe a connected issue the metronome (using audio beeps) only sounds while I am playing guitar over direct monitoring. If I stop playing the metronome cuts out.
Would appreciate any help here!
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 26 August 2013 - 04:32 AM
I've has a similar thing happen with logic... in the end i found my timing was slightly off...
i went to the midi edit view and sure enough the initial note was just outside of the loop area...
dragged it inside the loop area and everything was fine...anyway... just something to look at.
it seems i anticipated the note just the tiniest fraction during count in.
#3 gruser
gruser
  • 7 posts
Posted 26 August 2013 - 08:18 AM
Thanks for the response Zap. This isnt just a recording problem. Even live playback, the first note "glitches" and plays slightly late. Subsequent notes are ok until there is a break in playing. Then the first note of the next section only glitches again, subsequent notes are again fine.
Its driving me mad!
#4 gruser
gruser
  • 7 posts
Posted 28 August 2013 - 12:18 PM
Any midi analysis tool I could download to diagnose this?
#5 gruser
gruser
  • 7 posts
Posted 31 August 2013 - 07:43 AM
The feedback from the Steinberg forums is that there maybe some gate function on the toneport? Do line 6 have gate functions for balancing the input and DAW? Could I have something misconfigured?  I see a gate button on the plugin but on or off produces the same behviour.
