Braided TRS Cable to use with Variax Cable Power Kit?
So I finally got sick of my battery always being dead on my JTV59 and purchased the Variax Power Cable Kit, which is AWESOME!...with one semi-major flaw for me...I can't seem to find a good long-length TRS cable to use with it!
I didn't realize initially that it needed a TRS until I received the included 15' cable.  I have become a HUGE fan of braided cables and can't seem to find a good braided cable to use with the power kit.  Anyone else have this problem and have you found a great braided cable to use?
I'll post if I track something down for future forum members.
-sd
Not sure if this will work, but I ended up "building" a braided 20' TRS using XLR adapters:
https://www.amazon.com/gp/product/B00NQPHIR4/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B000068O4I/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B0002GZLX8/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
Hopefully its not too bulky with the adapters, but I'll post if it works (or not).
-sd
TRS:: Tip/Ring/Sleeve in an active circuit like this is typically use for
signal, +Vdc and return (or some analog circuit common or ground).
Over long lengths, there can be a sag in the DC rail and/or a resulting
change in the impedance. Change in impedance can contribute to hum noise.
DC regulation can do only so much.
So yeah,... snhirsch has got it.
-sd
XLR cables are generally not shielded like guitar cables.
Loads of noise interference possibilities.
An unshielded microphone cable would be as useful as a screen door on a submarine.  Of course they are shielded, sometimes doubly so.
XLR is a balanced line, and the 3rd line ties to the shielf for chassis ground.
50-Ohm XLR is for mics, 110-Ohm XLR is for L6 Link.
TRS guitar is for guitars with active electronics like a Variax or JTV.
Because of impedance considerations and its affect on cable performance,
many of the afore mention cables have length limits. So don't go beyond that.
Is the JTV 1/4" output a TRS of some kind? I didn't know that. I'd use a VDI anyway, but that doesn't work with everything.
