Gucio0 Posted September 9, 2016 Share Posted September 9, 2016 Hello guys, I'm the owner of GX interface, my question is : Can i connect the low price mini jack microphone to it using the mini jack -> big jack adapter? Spoiler : I tried it already, but It does not work. I got no idea why, does the GX need phantom to power this microphone (it has no leds so I can't tell where the problem is) Thanks :) Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 9, 2016 Share Posted September 9, 2016 The GX does not provide phantom power. If your mic is a condenser mic you will need another source to provide the necessary phantom power. 1 Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted September 9, 2016 Share Posted September 9, 2016 What 'low price mini jack' microphone are you trying to use? 1 Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 12, 2016 Share Posted September 12, 2016 It should work if it is not a condenser mic. Good chance you are not set up properly in POD Farm or the Line6 Audio-MIDI control panel. If you are using PF make sure to select Mic as the source. If you are not using POD Farm make sure to select Mic as the source in the Line6 control panel. 1 Quote Link to comment Share on other sites More sharing options...
Gucio0 Posted September 13, 2016 Author Share Posted September 13, 2016 What 'low price mini jack' microphone are you trying to use? Trust MC1200 - i'm just using him for skype, etc. It should work if it is not a condenser mic. Good chance you are not set up properly in POD Farm or the Line6 Audio-MIDI control panel. If you are using PF make sure to select Mic as the source. If you are not using POD Farm make sure to select Mic as the source in the Line6 control panel. Seems like that's a condenser mic, problem solved. http://www.trust.com/en/product/11917-primo-microphone That's for your help guys :)) Quote Link to comment Share on other sites More sharing options...
