Gary_T Posted September 10, 2016 Share Posted September 10, 2016 I will do the Best I can to describe this. I have owned my HD 500 X for about 6 months now. A couple of months after owning it it made this low frequency type of noise. It kind of startled me so I shut everything down. When I turned everything back on, the noise went away. Now fast forward to tonight and it made the noise again. At first I did not know if it was the power amp or of the pod making the noise, but tonight I verified that it was the pod. When the noise happened, I went over to the power amp and turned it down. The noise was still present. I went back to the pod and switched the preset and the noise went away. Has anyone else experienced this? I know it's kind of hard to imagine what I'm talking about because you really have to hear the noise to understand. And the best I can tell you is that if you strummed a Drop C chord, that's kind of what it sounds like, for lack of a better explanation. This has happened twice so there is no rhyme or reason or anything that I have done that could have created the sound. Should I contact line 6 and have them look at it? Any help would be greatly appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
GaryT898 Posted September 13, 2016 Share Posted September 13, 2016 I did not understand exactly what kind of noise are you talking about, but I and others in the past have had problems due to a sudden very loud noise that appeared after installing some firmware versions, which was later resolved by upgrading to an newer bug fixed version .. Thank you for your response. Imagine strumming a chord in "C" and thats the best example I can give you. It was sudden, but did not stop until I switched between presets. I will check my firmware to see if I am running that version. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 13, 2016 Share Posted September 13, 2016 Even if you are running the latest version, installing the latest version can cure many problems. It is sort of like reseting your phone or reinstalling Windows. You don't get anything new, but you do get a fresh install. Quote Link to comment Share on other sites More sharing options...
