Poor Audio Recordings With My Line 6 Pod Ux1
bad audio
10 replies to this topic
#1 sidguitarrist
sidguitarrist
  • 7 posts
  • Registered Products:1
Posted 28 August 2013 - 10:00 AM
Hi people,im having some issues with the line 6 pod ux1.Im trying to make a song and i dont know how to get a decent audio recording.I have tried a lot of things with ux1 configuration and the quality stills bad,i dont know what else to do to get a good audio quaility when im recording.
im using my pod ux1 with cubase 5 and pod farm 2.55 in my pc with windows 7.
pls help,im very fustrated with this thing :( .
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16056 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 28 August 2013 - 10:08 AM
Are you following the information in the Pod Farm recording setup guide?
http://line6.com/dat...h ( Rev A ).pdf
... especially the Cubase Setup on page 6-62.....
.... John Lennon
#3 sidguitarrist
sidguitarrist
  • 7 posts
Posted 28 August 2013 - 03:32 PM
mate i have done all the things that i saw in that guide pdf,and still sounds bad.i dont know what else do.I think my problem its with the low volume in the instrument input. Could you help me to change de volume of the input instrument?
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16056 posts
Posted 28 August 2013 - 06:11 PM
Can you be more specific about what you are doing, and how you have things set up? Provide as much detail as you can.Can you post a sample of the recording? Perhaps screenshots of Pod Farm/Cubase that you think may illustrate the problem? Are you able to adjust the input volume for the track when recording in Cubase?
It's very difficult to provide hints and suggestions when you say you've already done everything, and that 'things still sound bad'.
.... John Lennon
#5 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2575 posts
  • LocationNew England
  • Registered Products:3
Posted 29 August 2013 - 04:39 AM
When you indicate 'low volume' - what is the actual volume showing in Cubase?  You should be recording in the -18dB to -12dB range.
#6 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7365 posts
  • Registered Products:6
Posted 29 August 2013 - 07:30 AM
Are you saying what you play sounds good but the recording does not?
Check what you are sending to Cubase in POD Farm's mixer view.
You can send dry, processed, or semi-processed?
Also make sure you are using ASIO UX1 as you device in Cubase.
#7 sidguitarrist
sidguitarrist
  • 7 posts
Posted 29 August 2013 - 04:44 PM
here you got a lot of screen shots with my configuration while i was using the line 6 pod ux1 in cubase 5 and an audio test that i recorded to show you the low quality of my recordings.
#8 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16056 posts
Posted 29 August 2013 - 05:31 PM
Are you saying that it sounds better to you when listened to live? I'm not a metal fan so I'm not a good judge of whether this recording sounds good or bad. Sorry I can't help - perhaps someone with a good ear for metal can assess the sound quality.
Offhand I don't see anything obviously wrong with your setup; on the other hand my knowledge in this area is general - I own and use several audio interfaces and DAWs, but not the UX1 or Cubase.
Good luck working things out.
.... John Lennon
#9 sidguitarrist
sidguitarrist
  • 7 posts
Posted 01 September 2013 - 05:24 AM
i heard a lot of recordings in youube with the pod ux1 and it sounds bettter in quality than mines,and i always keep the same configuration as they do in theri recordings  :(
#10 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16056 posts
Posted 01 September 2013 - 05:56 AM
Ah, yes - expecting your own recordings to sound like youtube..... There are SO MANY things, other than your device and its settings, that go into youtube recordings and playbacks. It is almost impossible to reproduce everything exactly, and its unrealistic to expect identical sound.
The real question for you is: is your recorded sound similar to the sound you hear when monitoring your sound in your DAW before recording it, and when playing live (without recording)? If the answer is yes, then there's nothing wrong with your recording.
If you don't like the sound you hear (live and/or recorded), then the issue is with your equipment and its settings, not with your recording. You simply need to spend the time required to learn your equipment, its capabilities, and the settings that sound good to you personally.  If you have experience with such things then it shouldn't take long to get good sounds from the UX1 and Pod Farm.  If you need more experience - then keep working at it.
.... John Lennon
#11 sidguitarrist
sidguitarrist
  • 7 posts
Posted 12 September 2013 - 09:49 AM
im having the same issues,i think the problem its in the line 6 ux1 inputs at low level,that is creating a low quality audio recordings,anybody knows what to do in that case or how to use a  virtual pre amp while im recording?
Also tagged with one or more of these keywords: bad audio
