Latency By Switching 'pickups'
5 replies to this topic
#1 janssengr
janssengr
  • 7 posts
  • Registered Products:2
Posted 28 August 2013 - 11:06 AM
Hi all,
Just a quick question. I have a JTV 89. Is it normal to notice latency by switching pickups in Variax mode?
I mean: for example if I play a solo, quite often I switch between neck and bridge pickups, within one and the same model such as the Spank. So moving the pickup switch selector from 1 to 5 or vice versa.
I do notice quite some lag while doing this, and a drop in sound as well. I do understand that you basically move to a different model on the guitar, so that volume difference probably exist between the different models within one bank. But it would be great if the Variax 'caches' all the models in one bank when you switch to it, so it can switch effortlessly.
is this normal behaviour or is there perhaps something wrong?
I updated to the 2.0 firmware which by the way sounds very nice.
cheers!
Robbert
#2 stevekc
stevekc
    Gear Head
  • PipPipPip
  • 776 posts
  • LocationSan Luis Obispo, CA USA (central coast)
  • Registered Products:14
Posted 28 August 2013 - 11:11 AM
This is normal (sadly)
  • 1
#3 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 28 August 2013 - 11:14 AM
Only one model is running at a time.  IT's not good to have any sound being generated when you switch models.  The selector switch is switching models same as the model knob does.
#4 nikoniablue
nikoniablue
    Iknowathingortwo
  • PipPip
  • 102 posts
  • LocationSt Albans, England
Posted 28 August 2013 - 10:47 PM
The best solution for you is probably to create a custom bank and tweak the models within it to the same volume.  That won't sort the lag but it will solve half the problem.
#5 stevekc
stevekc
    Gear Head
  • PipPipPip
  • 776 posts
Posted 30 August 2013 - 01:16 AM
Its a bummer - because the old variax's had less pops and less PU change latency
We'll have to compare and see if the Tyler Variax can accomplish this
http://www.vettavill...vworkbench5.htm
In April 2005 Vettaville.nl posted a video with a Whammy like effect using the tone selector switch on the Variax. The demo was performed by Ron Huisen; Product Specialist for Line 6.
There have been several requests to explain how to do this. Here are the patches (tones) for Variax Workbench that you should place in order and upload to your Variax accordingly. Then you're ready to do the trick.
Please note that these are only tones for your Variax and no 'amp' tones. This is something you can choose yourself. The tones will work if you have the Variax Workbench program. Just click the links to view the video and download the tones. Have fun
http://vettaville.ne...ench Whammy.wmv
#6 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1818 posts
  • LocationGreece
  • Registered Products:12
Posted 31 August 2013 - 09:43 AM
Well, comparing the jtv with the old variax...The old was much more better in many aspects except the tone of some guitars..
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
