Mac OS Sierra Compatibility?
jeremybnz
  • 2 months later...
  • 2 weeks later...
was anyone able to get POD edit to work?
Don't quote me on this, but I think Line 6 Edit works in the JAVA environment.  So check to see if your are current for Java
Java 8 Update 111.  I could be totally wrong.
I am Sierra 10.12.2 on a MacBook Pro with 16 GB RAM.   Everything works flawlessly.
Cheers
Cheers
I checked and I am running the correct version of java and am also running Sierra 10.12.2. This is what happens in the installer though.
Thanks for the quick reply!
Good Luck.  I am not a techie person.  So I have no other suggestions.  With the Mac (formally was a windows guy), it just works.  Cheers
  • 2 weeks later...
  • 3 weeks later...
I had the same issue with Pod Farm:
  • Right click on the .mpkg,
  • "Show Package contents"
  • > Contents > Packages
  • Install all .pkg manually
It worked for me. I hope this will help you.
  • Downvote 1
  • 2 weeks later...
Hi everyone -
Im having the same issue- after downloading every possible update i can find from Line 6 drivers to upgrading from Mac OS capitan to Siera 10.12 to 10.12.3....when running HD 500x edit installer I am still getting this message saying i need mac os x 10.5 or greater...but i have greater! 10.12.3
Can we get some Live 6 pro help on this??
Can I downgrade to an OS that will work? What to do?
  • Sad 1
  • 4 weeks later...
Having acquired an HD500 after updating to Sierra 10.12.3
(so installing all most recent Line 6 software versions)
and installing JDK 1.6.0 for older Variax support from:
 https://support.apple.com/kb/DL1572
... POD HD500 Edit "just works".
When opening a Terminal window and typing:
$  java -version
java version "1.8.0_73"
Java SE Runtime Environment (build 1.8.0_73-b02)
Java HotSpot 64-Bit Server VM (build 25.73-b02, mixed mode)
  • Upvote 2
  • 2 weeks later...
  • 2 months later...
I have purchased a brand new HD500x and I'm unable to install HD500x Edit. I have OSX 10.12.4 (sierra) but I'm getting a message saying I cannot install because the software requires OSX 10.5 or above!
I have created my own patches and don't want to lose them, I also want the latest firmware for the HD500X but when trying to install the new firmware i am being warned to back up my HD500 to Edit......
Can anyone help?
  • 4 weeks later...
