ramirezdan Posted September 26, 2016 Share Posted September 26, 2016 I'm controlling Ableton Live with 9 of my stomps. These do nothing but send midi messages to Live. I'm reserving the 10th footswitch as an FX ON/OFF switch that controls the Helix's internal FX. I'm using snapshots to pick my guitar(or synth) sound. I've got a long serial set of blocks and was happily assigning Footswitch 1 to their bypass state when it became greyed out for the 8th effect. Since Footswitch one is already sending a midi command, it appears I've run into the "Each footswitch can have up to 8 assignments" limitation mentioned in the manual. So, short of reducing my blocks to 7 or fewer for my snapshots. Can anyone suggest a workaround? I basically need Footswitch 1 to send a clean DI signal when OFF, and a wet chain when ON. Bonus points for being able to adjust the wet/dry mix with EXP2. Quote Link to comment Share on other sites More sharing options...
ramirezdan Posted September 27, 2016 Author Share Posted September 27, 2016 In case anyone else is running into this. Here's how I semi-figured it out. Drag all the "Wet" blocks down so you get that little white circle. Change it to Split A/B. Where the A and B chains merge, click on the Merge Mixer and assign EXP2 to both A and B level. Then reverse the Min and Max settings for either path. This means you're 100% dry on one side, and 100% wet on the other. I suppose I could assign FS1 with the same assignments, but a wet/dry controller seems pretty nice too. Will have to try both ways to see which I prefer. Quote Link to comment Share on other sites More sharing options...
