chuskey Posted September 29, 2016 Share Posted September 29, 2016 I had a crack at making a POG/organ style effect with Helix. I did it using a Variax, but you could just as easily do it with a regular guitar. Here's a video about the patch: https://youtu.be/BcVZ3p644uY Here's a link to the patch: http://line6.com/customtone/tone/2500797/ 3 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted September 29, 2016 Share Posted September 29, 2016 I had a crack at making a POG/organ style effect with Helix. I did it using a Variax, but you could just as easily do it with a regular guitar. Here's a video about the patch: https://youtu.be/BcVZ3p644uY Here's a link to the patch: http://line6.com/customtone/tone/2500797/ +1 Great sound and tutorial, darn nice of you to contribute it to the community. Thanks! Btw, I have never set up a patch with two inputs for Variax magnetics. How does that work exactly? Quote Link to comment Share on other sites More sharing options...
chuskey Posted September 29, 2016 Author Share Posted September 29, 2016 +1 Great sound and tutorial darn nice of you to contribute it to the community. Thanks! Btw, I have never set up a patch with two inputs for Variax magnetics. How does that work exactly? You're very welcome! With paths 1A, 1B, 2A, and 2B you could have up to 4 separate inputs. Since I was pitch shifting the Variax digital signal I had to make sure to use the Variax Mags for the other paths. I setup 2 separate Variax Mag paths so I could use 2 different pitch shifters without them interfering with each other. If I wasn't using Variax I'd set all 3 inputs to guitar or multi and add a pitch block on patch 1A shifting up an octave, which is what I have the Variax digital signal doing. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted September 29, 2016 Share Posted September 29, 2016 You're very welcome! With paths 1A, 1B, 2A, and 2B you could have up to 4 separate inputs. Since I was pitch shifting the Variax digital signal I had to make sure to use the Variax Mags for the other paths. I setup 2 separate Variax Mag paths so I could use 2 different pitch shifters without them interfering with each other. If I wasn't using Variax I'd set all 3 inputs to guitar or multi and add a pitch block on patch 1A shifting up an octave, which is what I have the Variax digital signal doing. Clever use of routing, thanks for the explanation. Quote Link to comment Share on other sites More sharing options...
