unknown device pod HD300 drivers
hd300 drivers usb
1 reply to this topic
#1 gennaromicallo
gennaromicallo
  • 1 posts
  • Registered Products:1
Posted 06 October 2016 - 08:36 AM
Good morning,
I ask you please to help me.
I have a problem with the HD300 pod usb downloading the driver on pc tells me that the device is unknown and I can not connect it to your PC.
I have already reset the pod 300.
by starting the installation of the drivers from the .exe at one point he tells you that you should see a screen when connect usb HD300 pod asking you to force the installation of the driver for compatibility.
to me this pop up, this screen does not open, so I follow the procedure that tells me that the drivers are installed.
Also at the beginning when I linked the pod HD300 in the indication of the USB port and features I could see that the manufacturer was line6 that the door was appointed instead HD300 and now unknown device.
please give me a hand thanks
#2 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2483 posts
  • LocationMichigan
  • Registered Products:8
Posted 06 October 2016 - 09:01 AM
More than likely it is a problem with your PC recognizing the HD300 (unless it is a used HD that already had problems). Try using a different USB port.
If you still cannot get it to work, in order for someone to really help you, list your OS.
Smell the glove.
Also tagged with one or more of these keywords: hd300, drivers, usb
