Ux2 And Pod Farm Microphone
7 replies to this topic
#1 viktorlarsson
viktorlarsson
  • 7 posts
  • Registered Products:1
Posted 30 August 2013 - 09:41 AM
I bought the Line 6 UX2 a few days ago, plugging in my guitar and play works like a charm.
I'm having trouble with the microphone though. I've tried both Mic1, Mic2 and Mic stereo in the input and I tried to give the microphone the +48V boost on all of them, still no sound. What am I doing wrong?
I have a following question: Why is my second input(Tone B ) shadowed out? I would really like to be able to record both microphone and guitar at the same time.
(All the gain-knobs are on full)
Best regards
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9242 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 30 August 2013 - 10:25 AM
What type of mic are you trying to use?
The +48V button isn't a boost, btw. It's the phantom power switch. It provides 48V of DC power to mics that need it.
#3 viktorlarsson
viktorlarsson
  • 7 posts
Posted 30 August 2013 - 10:31 AM
Yes phil_m, I just like to use the word boost.
Its an sE X1, condensator, and the reason why I try both +48v and not, is because there is no proper manual with this thing so Im not too sure.
Thanks for the reply!
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9242 posts
Posted 30 August 2013 - 11:03 AM
Well, you definitely need phantom power on for that mic, but I don't know why you wouldn't be hearing any sound. Are the meters on the front of the UX2 moving?
#5 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 30 August 2013 - 11:48 AM
Make sure that the "DUAL" button next to the patch name is turned on in order to use channel B.
+48V should definitely be on for a condenser mic.
Are you sure that the MIC is in proper working order?
Do you get sound when you play a guitar and have the input set to "Instrument"?
#6 viktorlarsson
viktorlarsson
  • 7 posts
Posted 30 August 2013 - 12:06 PM
phil_m, they are not.
BigChas52, I don't know wether it is or not since I just got it, because with this UX2 soundcard I could use an XLR microphone rather than the USB ones I've used before. So there is no way for me to check either, really...
And yes, I do get sound when I play the guitar and the input set to instrument
I did see someone that got it to work by putting the input to Mic 1 or 2 and then quote:"Went into the Drivers Console..." but I can't find anything about a driver console..
#7 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 30 August 2013 - 12:23 PM
If POD Farm is running you shouldn't need the driver console.
The only other thing I can suggest is to make sure that you have the gain turned up on both the physical knobs on top of the UX2, as well as on whichever pre-amp models you are using for your vocals.
Can you post some screen shots?
#8 viktorlarsson
viktorlarsson
  • 7 posts
Posted 30 August 2013 - 12:54 PM
BigChas52 I somehow got it to work just now, I don't know how but all of sudden it worked, the meters doesnt show any incoming sound, but I can hear myself fine.
Sadly I don't have any resolution to contribute cept.. just fiddle till it jiddle!
