Spider Iv 150. Reboot
spider iv 150 reboot restart
14 replies to this topic
#1 Andres93
Andres93
  • 7 posts
Posted 30 August 2013 - 06:53 PM
Hi.
I have an Spider IV 150 amp with this problem: Reboot randomly. I bought this amp in 2010, but since 1 year (even more) i have this problem. I read the blogs, forums, and a lot of people have this problem, but nobody knows the solution... or dont write about it.
Im tired, i want to fix this issue.
#2 senanimach9
senanimach9
  • 25 posts
  • Registered Products:2
Posted 31 August 2013 - 11:25 AM
What are you doing when it reboots? Mine rebooted just a second ago, it was kinda weird. I was playing with a ton of different settings trying to get a tone down just right, then I accidentally switched amp models while turning another knob and it rebooted. It only happened for a split-second but I still noticed it..
#3 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
  • LocationNew England
  • Registered Products:3
Posted 03 September 2013 - 04:24 AM
Make sure you have the current revision of firmware installed (need to connect to Spider Monkey via an FBV MkII pedal and USB).   Also make sure the power cable is securely plugged in - I've noticed that the power cable on my 75 is not that great, seems like the socket is not tight or maybe not deep enough.
#4 senanimach9
senanimach9
  • 25 posts
Posted 04 September 2013 - 06:55 PM
Mine just rebooted while I was in INSANE mode, then switched to a preset and I guess the amp couldn't understand that I wasn't in Insane anymore even though the knob was still dialed to Insane. It rebooted and went back to normal. I tried to replicate it and nothing happened but it did happen before when I was scrolling through settings and amps like crazy..
#5 senanimach9
senanimach9
  • 25 posts
Posted 07 September 2013 - 08:21 PM
 I just noticed what you said about your power socket...mine is pretty loose and seems to want to come out of the amp if I were to tug on the cord at all, is that what yours does? I'm wondering if that's a Line 6 thing or if my amp is defective.
#6 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
Posted 08 September 2013 - 04:43 AM
I think that's the poor design and not defective.   Probably worth 'anchoring' the cable by using an insulated electric 'staple' (leave enough of a 'loop' so you can unplug the cable from the back of the amp when necessary).
#7 senanimach9
senanimach9
  • 25 posts
Posted 08 September 2013 - 07:34 PM
Hi.
Any solution yet?
#8 senanimach9
senanimach9
  • 25 posts
Posted 11 September 2013 - 09:57 AM
I realized something the other day.. the outlet that my amp is plugged into will not power my laptops ac adapter, weird huh? I also read about power fluctuations in wall sockets causing spider ivs to reboot if they're connected to the shortboard. So I cleaned any and all electrical connection on the amp just for the heck of it, along with the wall socket and got a decent surge protector to go between the wall and the amp. So far no reboots and it's been a few days now. In my case I honestly think the issue was the faulty wiring in my old old house.
#9 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
Posted 12 September 2013 - 06:15 AM
Glad you found the problem, but this also indicates that the outlet itself if faulty - and worth checking out, might be as simple as replacing it, but could also indicate poor old wiring that needs to be replaced before it overheats and possibly starts a fire.
#10 scoti65
scoti65
  • 1 posts
Posted 11 February 2014 - 05:32 PM
Mine has been doing it since I bought it. I've reset it repeatedly. Yesterday on a hunch I installed firmware version 1.52. Guess what, no more reboot issues. I have a feeling it is a programming error with version 2.0. I'm anxious to see if they release a newer revision to see if the trouble returns or not.
#11 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
Posted 13 February 2014 - 07:38 AM
You should start a support ticket on this.  There hasn't been a firmware update for a long time.
#12 bluebluetones
bluebluetones
    Iknowathingortwo
  • PipPip
  • 273 posts
  • Registered Products:1
Posted 17 March 2014 - 05:32 AM
I wrote extensively on this topic many years ago, when I bought the Spider IV 150 brand new upon release.
I initially thought I had solved the problem, and I never had any more re-boots.  I think I came to the conclusion that I needed a power conditioner on the wall outlet I use?
Fast forward to now - my original Spider IV 150 is gone, lost to the world of trading gear and amplifiers.  But I sure missed that great tone (especially Clean Green...) so I picked up another Spider IV150.
While recently editing a patch I had created, in the middle of nowhere, "thump"....the amp shuts down and starts again.  I can't believe it.  You know, I don't mind spending a bit of money to fix this problem so if anyone from Line 6 can tell me officially what need replacing I would be so happy!  Is is the "main board?"  How could I have two amps that do the same thing...there must be a part that is subject to weakness somewhere.
#13 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
Posted 18 March 2014 - 04:48 AM
Note that the Line 6 techs do not read this board.
#14 senanimach9
senanimach9
  • 25 posts
Posted 18 March 2014 - 04:50 AM
I'm finding that bad very few people do read these. And even less contribute, a bit of a bummer :-(
#15 Andres93
Andres93
  • 7 posts
Posted 29 July 2016 - 08:31 PM
Still no lucky with solutions, after this years... I gave up, but recently i wanted to check if any solutions came up on internet but no. Line 6 ignores all this lollipop.
