eayottes Posted October 15, 2016 Share Posted October 15, 2016 Hi,I've got a Line 6 studio GX plugged into a Windows 10 PC. I have ASIO4All installed. I also have run the Line 6 Monkey to make sure that the latest drivers for the studio GX are installed. If I try to use the Bias FX Pro (64 bit) standalone and set "device = ASIO", then I get the following error message when selecting "Output = ASIO GX": "ASIO driver open failure". See attached photo.Has anyone else encoutered this annoyance and if so, how did you resolve the issue ?Thanks in advance ! Quote Link to comment Share on other sites More sharing options...
aziarg Posted October 19, 2016 Share Posted October 19, 2016 I have the same exact problem. I can run it with ASIO4ALL but then Bias will take exclusive control of my toneport gx and I won't be able to run any other audio out of that interface into my speakers. Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 19, 2016 Share Posted October 19, 2016 I currently do not have BIAS, but I have seen similar behavior with other non-DAW standalone applications that use ASIO, as well as with other non Line6 ASIO devices. Do you have another application using the GX drivers running like a DAW or that previously was running? Try disabling the GX, then re-enable it before opening BIAS. You might also want to try uninstalling ASIO4ALL and reboot your pc to make sure it's not a driver conflict. Quote Link to comment Share on other sites More sharing options...
GansAles Posted November 23, 2017 Share Posted November 23, 2017 So, any update on this problem? Have the same issue - Windows10 x64, POD GX. Bias FX crashes at the moment i choose GX as device in BIAS FX audio settings. I have no asio4all, GX drivers is up to date. I have another interface (Yamaha THR) and it works fine with Bias Fx. Quote Link to comment Share on other sites More sharing options...
