Studio GX ASIO driver problems with Bias FX standalone
I've got a Line 6 studio GX plugged into a Windows 10 PC.
I have ASIO4All installed.
I also have run the Line 6 Monkey to make sure that the latest drivers for the studio GX are installed.
If I try to use the Bias FX Pro (64 bit) standalone and set "device = ASIO", then I get the following error message when selecting "Output = ASIO GX": "ASIO driver open failure". See attached photo.
Has anyone else encoutered this annoyance and if so, how did you resolve the issue ?
Thanks in advance !
I currently do not have BIAS, but I have seen similar behavior with other non-DAW standalone applications that use ASIO, as well as with other non Line6 ASIO devices.
Do you have another application using the GX drivers running like a DAW or that previously was running?
Try disabling the GX, then re-enable it before opening BIAS.
You might also want to try uninstalling ASIO4ALL and reboot your pc to make sure it's not a driver conflict.
  • 1 year later...
So, any update on this problem?
Have the same issue - Windows10 x64, POD GX. Bias FX crashes at the moment i choose GX as device in  BIAS FX audio settings.
I have no asio4all, GX drivers is up to date.
I have another interface (Yamaha THR) and it works fine with Bias Fx.
