rocksprite Posted August 31, 2013 Share Posted August 31, 2013 In other articles they say i have to screw both hex and the nut but i cannot screw the nut is there any way to fix it?? What should i do?? Allen key doesnt work it's not able to be tight or loose Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 31, 2013 Share Posted August 31, 2013 When you say that the allen key doesn't work - what exactly do you mean? Are you sure you are using the right size key? Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted August 31, 2013 Share Posted August 31, 2013 is there no access to the nut? Quote Link to comment Share on other sites More sharing options...
rocksprite Posted August 31, 2013 Author Share Posted August 31, 2013 When you say that the allen key doesn't work - what exactly do you mean? Are you sure you are using the right size key? well i guess its the right size but i'll try other allen key Quote Link to comment Share on other sites More sharing options...
rocksprite Posted August 31, 2013 Author Share Posted August 31, 2013 is there no access to the nut?nope Quote Link to comment Share on other sites More sharing options...
gmajorseven Posted November 5, 2013 Share Posted November 5, 2013 The Pedal has one long screw, that has a Nut on it. The frame of the pedal where the Nut is located, is design to lock the nut in place, while the Screw is being turned. The Nut don't turn. Quote Link to comment Share on other sites More sharing options...
MusikMicke Posted January 16, 2016 Share Posted January 16, 2016 Hi guys, Two years later... I have the same problem and need som help from HD500 (not X) owners: Can anyone tell me the exact size of the allen key that fits the bolt/screw to tighten the expression pedal? Thanks a lot, ROCK ON!Mike from Stockholm, Sweden. Quote Link to comment Share on other sites More sharing options...
duncann Posted January 16, 2016 Share Posted January 16, 2016 3/16" will work. 1 Quote Link to comment Share on other sites More sharing options...
