How to make a mid cut?
CBTL
I need some help, I'm the first to admit I don't have much of a clue about EQ frequency, where to place EQ In a chain or what model to use etc. When using a rotary cab it makes the sound very mid heavy from what I perceive. How am I best to tame this. I'm guessing by using a EQ block after MOD block that I can switch in and out together as I don't want to adjust my amps mid control. Any help would be greatly apreaciated.
Keep in mind that, as the name suggests, rotary cab is a cab already, so you better try to deactivate your cab emulation and place it after the amp block, first.
If you prefer having it in line before your amp block, the best option is to place a parametric eq after it and to boost the mids until you feel you're exaggerating the frequency you dislike, and after that you cut it out.
What's a "Q"
Simply put, Q defines how selective the frequency filter is.
As you can see here, a high Q means a steep filter, with fewer frequencies (around the center frequency) getting attenuated or amplified.
A low Q means a more gradual filter, with more frequencies getting attenuated or amplified.
Hope this helps!
Image courtesy: http://www.tubetrap.com/bass_traps_articles/room-acoustics-pics/
What's a "Q"
Q factor controls the bandwidth—or number of frequencies—that will be cut or boosted by the equaliser. The lower the Q factor, the wider the bandwidth (and the more frequencies will be affected).
https://howtoeq.wordpress.com/2010/10/07/q-factor-and-bandwidth-in-eq-what-it-all-means/
You may want to experiment with putting the EQ before or after your amp/cab block rather than after the 'MOD' block although after the rotary cab effect, as you suggested, sounds like the most logical location to try first . I would try arislaf's approach with a parametric EQ and move the frequency around the area he recommends until it sounds right to you. You can also try the 10 band graphic EQ or even the Cali EQ (Mesa Boogie) if you are more comfortable with them or get a better result.
